- Thank you received: 31
Conda installers available!
5 years 10 months ago #2175
by matthiash
Replied by matthiash on topic Conda installers available!
I'm not (yet) a conda expert, but I think your given hint is wrong. That's the path to the uninstalled package.
For me a hint is not necessary, conda sets PATH appropriately such that cmake finds Netgen/NGSolve automatically:
Netgen_DIR:PATH=/home/mhochsteger/miniconda3/envs/ngs/lib/cmake/netgen
NGSolve_DIR:PATH=/home/mhochsteger/miniconda3/envs/ngs/lib/cmake/ngsolve
- creativeworker
- Senior Member
5 years 10 months ago - 5 years 10 months ago #2176
by creativeworker
Replied by creativeworker on topic Conda installers available!
Ok, i see it has something to do with the path variables.
FYI: I created an own conda environment for the NGSolve installation. Activating it in the shell gives the possibility to open netgen just by typing netgen to the terminal. That works.
But I can't find any Path variables as you showed in the post? The second thing is then to apply those environment variables of the conda environment to CLion, where cmake is started.
For curiosity I installed netgen via the classical way. Then the C++ Extension compiles as expected, but of course installs into the 'old' structure, which is then not used with the conda package (of course as expected).
P.S.: The update of netgen and ngsolve with conda worked flawless.
Last edit: 5 years 10 months ago by creativeworker.
5 years 10 months ago - 5 years 10 months ago #2179
Replied by christopher on topic Conda installers available!
Did you have the conda environment activated when you ran the cmake configure?
I think this is the problem because you configure in clion. Maybe it is already enough to run clion in the venv. If not maybe run the cmake command by hand in the venv.
If you don't have it activated it won't find it, if you have it activated it should correctly install it into the virtual env as well.
Last edit: 5 years 10 months ago by christopher.
5 years 10 months ago #2180
Btw you will most likely have to install the conda package pybind11 as well if you want to compile an ngsolve extension in a conda env.
- liubenyuan
5 years 10 months ago #2195
by liubenyuan
Replied by liubenyuan on topic Conda installers available!
Hi, thanks for the ngsolve conda cloud.
However, it seems like libngsolve.so or some dynamic libraries are not properly installed. For example,
libngsolve.so is placed at /usr/share/miniconda3/pkgs/ngsolve-6.2.1909-py37_91/lib/netgen Maybe we should add an script telling its location whenever we reinstalled a new version of ngsolve.
ERROR:root:Cannot activate multiple GUI eventloops
togl-version : 2
OCC module loaded
loading ngsolve library
cannot load ngsolve
error: couldn't load file "libngsolve.so": libngsolve.so: cannot open shared object file: No such file or directory
5 years 10 months ago - 5 years 10 months ago #2200
by matthiash
Thanks for the report. We are currently working on an issue that is probably related to yours. A workaround is to set the LD_PRELOAD environment variable to the tcl library. In my case it's working by starting python like this:
Anyway I would like to check the directory structure of your installation. Pleases post the output of following commands:
LD_PRELOAD=/home/mhochsteger/miniconda3/lib/libtcl8.6.so python3
python3 -c "import netgen;print(netgen.__file__)"
python3 -c "import ngsolve;print(ngsolve.__file__)"
Last edit: 5 years 10 months ago by matthiash.
Time to create page: 0.146 seconds
