- Thank you received: 31
Conda installers available!
5 years 10 months ago #2169
by matthiash
Conda installers available! was created by matthiash
Experimental conda installers are now available. For instructions refer to the
downloads page
Currently not supported is :
In case you experience any issues, please post them here.
- Code generation at run-time
- creativeworker
- Senior Member
5 years 10 months ago #2170
by creativeworker
Replied by creativeworker on topic Conda installers available!
I tried today on macOS 10.15 in combination with Anaconda 2019.10
It works perfectly! I works with Spyder and PyCharm.
Just a small note, I used the following commands to add channels
conda config --add channels conda-forge
conda config --add channels ngsolve
conda install ngsolve
5 years 10 months ago #2171
by matthiash
Replied by matthiash on topic Conda installers available!
Thanks for the feedback, I fixed the commands on the download page
- creativeworker
- Senior Member
5 years 10 months ago #2172
by creativeworker
A second thing that I just noticed:
When I want to compile my C++ Extensions, CMake can't find the cmake files:
I think the find_package command in the NGSolveConfig.cmake has to be updated.
NetgenConfig.cmake
netgen-config.cmake
5 years 10 months ago #2173
by matthiash
mylittlengsolve builds fine on my Mac (also 10.15). Make sure you have no other NGSolve installation available. Maybe cmake is finding the wrong Netgen or NGSolve in /Applications/Netgen.app?
In case you cannot fix the issue, post/send the CMakeCache.txt file in you build directory.
Anyway, there is still another bug: compiled python modules shall not link to libpython, as it is statically linked to the python executable in conda. This results in a segfault when loading the module. A fix in the cmake function add_ngsolve_python_module() will be released later today.
- creativeworker
- Senior Member
5 years 10 months ago #2174
by creativeworker
Thanks for your fast reply. The installation is complete clean, so I'm sure there is nowhere else the NGSolve and I double checked that there are not any false environment variables.
Find attached the CMakeCache.txt. To produce this I only changed the CMakeLists.txt to give the find_package function a hint to the ngsolve CMake file:
So, perhaps you have set up environment variables that I don't have?
HINTS /Users/username/opt/anaconda3/pkgs/ngsolve-6.2.1909-py37_91/lib/cmake/ngsolve
