ngsxfem installing issues
2 years 7 months ago #4683 by hvwahl
Replied by hvwahl on topic ngsxfem installing issues
Hi Diana,
I don't know why that error persists. The latest dev builds on pypi are built with ngsolve 6.2.2301 from pypi, so they should be compatible. Maybe try and remove ngsolve/netgen and xfem and try a fresh installation of everything. Otherwise, the fastest way to get xfem working would be to build it  from source
Best wishes,
Henry
2 years 7 months ago #4686 by hvwahl
Hi Diana,
one more suggestion: Remove your current xfem, ngsolve, netgen installations, install the ngsolve version compatible with the last stable release of xfem (pip install ngsolve==6.2.2204) and then install xfem (pip install xfem).
Hope this helps.
Best wishes,
Henry
2 years 7 months ago #4708 by dianam
Replied by dianam on topic ngsxfem installing issues
Hi Henry,
Sorry for the late reply. Just wanted to say this worked! Thank you for your assistance :)
Diana
2 years 7 months ago #4711 by dianam
Hi Henry,
I'm getting a new laptop setup with all of the required packages and now when I try "pip install ngsolve==6.2.2204" in terminal I get an error message that states:=====================================================================================
ERROR: Could not find a version that satisfies the requirement ngsolve==6.2.2204 (from versions: none)ERROR: No matching distribution found for ngsolve==6.2.2204
What could be the reason for this? I'm afraid of installing a newer ngsolve version in case there's compatibility issues with xfem (which I am yet to install on this new machine). I appreciate your help!
Diana
