Boundary definitions and Dirichlet BCs on specific DOFs for vector valued funcs
5 years 11 months ago - 5 years 11 months ago #1836
Replied by christopher on topic Boundary definitions and Dirichlet BCs on specific DOFs for vector valued funcs
The difference is mainly in internal memory layout, the H1(..., dim=2) defines a space with vector valued degrees of freedom. So each dof is a vector with 2 components, each matrix entry is actually a 2x2 matrix,...
The VectorH1 is a compound space of multiple H1 spaces. Actually almost the same as doing
with the difference, that the VectorH1 defines additional convenience functionality like taking the gradient, divergence, ...
This is why it is not possible to define only the x component as dirichlet in the H1(dim) space but it is possible in the VectorH1. But one could achieve fixed boundaries for the H1 space by penalizing with robin boundary terms.
I'll look into the segfault
vech1 = FESpace([h1,h1])
Last edit: 5 years 11 months ago by christopher.
5 years 11 months ago #1852
by anandes
Replied by anandes on topic Boundary definitions and Dirichlet BCs on specific DOFs for vector valued funcs
Hi Christopher,
I just wanted to check back with you if you are able to duplicate the segfault issue with mesh refinement. If so, please let me know if there is a way to resolve the problem.
Thank you,
Anand
Thank you,
Anand
5 years 11 months ago #1857
Hi sorry I forgot to answer.
I think I fixed that, at least in my version now I cannot reproduce a segfault. We are putting out a new release today (1907), tell me if you still segfault with it.
5 years 11 months ago #1866
by anandes
Hi Christopher,
Thanks for the fix! I'm now able to run the problem with multiple uniform refinements and no segfaults (in release 1907).
Thank you,
Anand
Thank you,
Anand
5 years 10 months ago #1995
by anandes
Hello Christopher,
I have a follow-up question on this topic. Using your suggestion, I am able to apply homogeneous Dirichlet BCs on specific DOFs of a discretization of a VectorH1 space.
How can non-homogeneous Dirichlet BCs be applied on such DOFs? To be more specific, I have attached a NGSolve python file and an associated vol file. Is there a way to apply non-zero Dirichlet BCs (only in the y-direction) on the boundary marked "Pres_load" ?
Thank you,
Anand
Thank you,
Anand
5 years 10 months ago #1997
by hvwahl
Replied by hvwahl on topic Boundary definitions and Dirichlet BCs on specific DOFs for vector valued funcs
Hello Anand,
non-homogeneous slip BCs should be a combination of what you have done and Docu: Non-homogeneous Dirichlet data .
First mark te appropriate dofs as Dirichlet and store them for later:
Then add the non-homogeneous data to the solution grid function at the appropriate dofs and solve the system as in the documentation:
I hope this helps
Henry
pres_load_dofs = []
for el in fesx.Elements(BND):
if el.mat == "Pres_load":
for dof in el.dofs:
freedofs.Clear(fesx.ndof+dof)
pres_load_dofs.append(fesx.ndof+dof)
gfu.vec[:] = 0.0
for dof in pres_load_dofs:
gfu.vec[dof] = 1
# Obtain solution
res = gfu.vec.CreateVector()
gfu.vec.data += a.mat.Inverse(fes.FreeDofs(), inverse="sparsecholesky") * res
I hope this helps
Henry
