Boundary definitions and Dirichlet BCs on specific DOFs for vector valued funcs
5 years 10 months ago #1999 by anandes
Hello Henry,
Thank you for your detailed response. It works as expected for linear elements. But when I try this on elements of order 2, the displacements at mid-nodes are not the same as the applied value.
I print the values in gfu.vec corresponding to these DOFs and the values are as applied. But when I print the gfu(
5 years 10 months ago #2000 by anandes
Hello Henry,
However, when I try this on elements of order 2, the displacements at mid-nodes are not the same as the applied value (uy=0.01 on the top surface). I tried to ensure that the Dirichlet BCs are applied even on the mid-nodes (edge dofs) of the top surface.
I print the values in gfu.vec corresponding to these DOFs and the values are as applied. But when I print the gfu(mesh()) values corresponding to the mid-nodes, the values are incorrect. I have attached the python script. Can you please tell me if this is just an artifact of post-processing or if there is actually an error in the solution?
Thank you,
Anand
5 years 10 months ago - 5 years 10 months ago #2003 by christopher
Hi Anand,
the standard H1 space in NGSolve does not have a nodal basis, but instead a hierarchical. If you want a nodal space you can create it with
fes = FESpace(type="nodal", mesh=mesh, ...)
then you can use the space as you expected.
If you want to define inhomogeneous bc for the hierarchical space use the Set function of the GridFunction.
Last edit: 5 years 10 months ago by christopher.
5 years 10 months ago #2011 by anandes
Hi Christopher,
Thank you for clarifying the reason for this discrepancy.
However, when I try nodal basis functions as you suggested with the following line:
fes = VectorH1(mesh=mesh, ele_order=2, type="nodal"),
I get the following warning -
WARNING: kwarg 'type' is an undocumented flags option for class <class 'ngsolve.comp.VectorH1'>, maybe there is a typo?,
and the error still persists on the mid-nodes of the element edges
As to your other suggestion, I am unable to use the "Set" function to apply non-homogeneous Dirichlet BCs on the hierarchical basis as there is no option in NGSolve to use the "Set " function to apply BCs on specific DOFs of vector-valued functions on the boundary. If I do, then the non-zero values are applied to all DOFs along that boundary.
Thank you,
Anand
5 years 10 months ago #2012 by christopher
Not VectorH1
Vi = FESpace(type="nodal", mesh=mesh, order=2)
fes = FESpace([Vi, Vi])
Best Christopher
5 years 10 months ago #2019 by anandes
Hi Christopher,
When I declare the FESpace as you suggest, the code works as expected for order = 1 (this also requires other changes to the script as some utilities like div, grad, do not work for compound FE spaces - you had mentioned this earlier).
However, for any order > 1 NGSolve throws the following error:
catch in AssembleBilinearform 2: Inconsistent number of degrees of freedom, vb=VOL fel::GetNDof() = 12 != dnums.Size() = 6!
One problem seems to be that fes.ndof is fixed at the same value (as fes.ndof for order=1) even when any order >1 is used.
I have attached the sample python script for your reference.
Thank you,
Anand
File Attachment:
File Name: SEC_2D_dis...10-29.py
File Size:6 KB
