Data Race Condition while using AddElementMatrixSymmetric
6 years 8 months ago #1369
by jhauser
Replied by jhauser on topic Data Race Condition while using AddElementMatrixSymmetric
With this I get the error:
‘class std::shared_ptr<ngla::SparseMatrixSymmetric<double> >’ has no member named ‘SetZero’
I used
as a work around, but I still get a similar wrong matrix. Different every time I run the program.
At least with the python script. (I use python 3 to execute it) If I use "MyMaxwellAssembleSMALL" in jupyter notebook, I get the correct matrix. (which is printed in my terminal, when I use this function)
I used
for(int i=0; i<ndof_y;i++)
FlatVector<double> mat_rowvals = maty->GetRowValues(i);
for (int k=0; k<mat_rowvals.Size(); k++)
mat_rowvals[k]=0.0;
6 years 8 months ago #1370
if matrix is a shared pointer
Replied by joachim on topic Data Race Condition while using AddElementMatrixSymmetric
matrix -> SetZero()
6 years 8 months ago #1371
by jhauser
Oh, you're absolutely right. Thank you!
However the problem still remains. This doesn't change the every changing entries of the matrix. It's still different every time I run it.
6 years 7 months ago #1373
Replied by christopher on topic Data Race Condition while using AddElementMatrixSymmetric
With maty->SetZero() I get consistent results, can you repost the new version of your code?
to get the output in jupyter (you need to include pybind11/pybind11.h to have that).
This is because jupyter pipes only the python stdout and not the c++ one. You can use(which is printed in my terminal, when I use this function)
pybind11::print(maty)
6 years 7 months ago #1375
by jhauser
I cleaned out the cmake-files of ml-ngs and build/compiled everything anew.
Now it works. I have absolutly no idea why it didn't work before since I haven't changed the code.
Thank you very much for your time! I am sorry, that it took so long.
And thank you for the jupyter suggestion.
