Data Race Condition while using AddElementMatrixSymmetric
6 years 8 months ago #1363 by jhauser
I am still working on the implementation of the assembling in tensor product spaces. For that I need the local mass matrix of HCurl-functions. My resulting matrix seems mostly right, but there are a few entries that are wrong. It changes each time which entries are influenced. The error only occurs when I use a python script with python3. If I use the interface of jupyter notebook, my matrix is correct.
The local matices seem to be correct therefore I guess that it is a problem with AddElementMatrixSymmetric or rather a data race condition in IterateElements.
How can I slove it?
The code with this problem is as follows:
template<int Dy> void CalcElementMatrix_tpy(const FiniteElement & fely, const ElementTransformation &eltrans_y, LocalHeap & lhy, FlatMatrix<double> elmaty) { const HCurlFiniteElement<Dy> & fely_cast = dynamic_cast<const HCurlFiniteElement<Dy>&>(fely); ELEMENT_TYPE eltypey = fely_cast.ElementType(); int ndy = fely_cast.GetNDof(); const IntegrationRule & ir_voly = SelectIntegrationRule (eltypey, 2*fely_cast.Order()); MatrixFixWidth<Dy,double> shapey(ndy); elmaty = 0.0; for (int l = 0; l < ir_voly.Size(); l++) { HeapReset hr(lhy); const MappedIntegrationPoint<Dy,Dy> sip(ir_voly[l], eltrans_y); BaseMappedIntegrationPoint & mip = eltrans_y(ir_voly[l], lhy); fely_cast.CalcMappedShape (mip, shapey); elmaty += ir_voly[l].Weight() *sip.GetMeasure()* shapey * Trans (shapey); } } ... shared_ptr<GridFunction> MyMaxwellAssemble(shared_ptr<FESpace> fes_in, shared_ptr<CoefficientFunction> f_coef) { ...... IterateElements(*fes_y, VOL, lhy, [&] (FESpace::Element ely, LocalHeap &lhy) { const ElementTransformation& eltrans_y = ma_y->GetTrafo(ely, lhy); const FiniteElement& fely = fes_y->GetFE(ely,lhy); FlatArray<DofId> dofsy = ely.GetDofs(); FlatMatrix<> elmat_fesy(dofsy.Size(),lhy); CalcElementMatrix_tpy<2>(fely,eltrans_y,lhy,elmat_fesy); maty->AddElementMatrixSymmetric(dofsy,elmat_fesy); }); .... }
6 years 8 months ago #1364 by christopher
Do you use a standard HCurl space? IterateElements uses the coloring of the finite element space to decide which elements can be assembled at the same time.
6 years 8 months ago - 6 years 8 months ago #1365 by jhauser
Yes, I use the standard HCurl space:
meshx = Mesh(unit_square.GenerateMesh(maxh=0.5)) fesx = HCurl(meshx,order=1)
Last edit: 6 years 8 months ago by jhauser.
6 years 8 months ago #1366 by joachim
Are you using the TaskManager ?
If not, IterateElements is not parallel anyway.
If yes, what happens without ?
Is the x-space or the y-space the HCurl ? The C++ part and the python part look inconsistent.
Your code snipped looks reasonable. It's difficult to help with this information. Maybe you can upload a full example producing this random results.
6 years 8 months ago #1367 by jhauser
No, I do not parallelize it. That's why I have no clue what's the real problem.
Here a shortened version of my code, which still produces the error on my computer:
I am currently working in the ml-ngs file system. The two files which I've attached, I put into /1_Basic/4_utility_functions. The following lines I added in utility_function.hpp (in /1_Basic/4_utility_functions):
namespace mymaxassembleSMALL { void MyMaxwellAssemble_small(shared_ptr<FESpace> fes_in, shared_ptr<CoefficientFunction> eps_coef, shared_ptr<CoefficientFunction> mu_coef, shared_ptr<CoefficientFunction> f_coef); }
and added
m.def("MyMaxwellAssembleSMALL", &mymaxassembleSMALL::MyMaxwellAssemble_small);
in myngspy.cpp (in /1_Basic) to the list of exported functions in the end of the file. Of course I added "4_utility_functions/myMaxAssembling_small.cpp" in CMakeLists.txt to "add_ngsolve_python_module" as well.
6 years 8 months ago #1368 by joachim
after creation of a sparse matrix, it is NOT zero-initialized.
You have to call
matrix.SetZero()
