custer installation issue (again)
7 years 2 months ago #698 by Guosheng Fu
Hi guys,
I am going through the same installation issue again....
A year ago, with your help I have installed ngsolve in a cluster... but I have no access to the cluster anymore....
Now, I would like to get ngsolve installed on my local cluster, but it cause issue again as usual.
So, after make install, I got the following error message at the final linking stage (100%):
/users/gfu1/data/ngbuild/ngsolve-install/lib/libmesh.so: undefined reference to `gzclose'
/users/gfu1/data/ngbuild/ngsolve-install/lib/libmesh.so: undefined reference to `gzwrite'
/users/gfu1/data/ngbuild/ngsolve-install/lib/libmesh.so: undefined reference to `gzopen'
/users/gfu1/data/ngbuild/ngsolve-install/lib/libmesh.so: undefined reference to `gzread'
A similar linking issue was found a year ago, but the fix there was simple...here I don't have a clue what's going on
Guosheng
7 years 2 months ago #700 by cwinters
sounds like you are missing "zlib".
On my ubuntu 18.04 the package "zlib1g-dev" contains what you need. But at least for ubuntu, I thinks that's installed by default. Which OS are you using?
7 years 2 months ago #703 by Guosheng Fu
interesting....
I do have a zlib(what is there!?) issue initially, so, I passed the flags in cmake to the correct location
DZLIB_xxx=...
to locate zlib
I thought this shall be enough
7 years 2 months ago #704 by Guosheng Fu
We have a RedHat7 system...
7 years 2 months ago #706 by cwinters
you could check your netgen cmake cache. This file is located in the netgen subfolder of you ngsolve build folder.
My CMakeCache.txt contains these lines.
//Path to a file. ZLIB_INCLUDE_DIR:PATH=/usr/include //Path to a library. ZLIB_LIBRARY_DEBUG:FILEPATH=ZLIB_LIBRARY_DEBUG-NOTFOUND //Path to a library. ZLIB_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libz.so
Which variable did you set? The location of the following variable should be used as hint to search for the header and the library.
-DZLIB_INCLUDE_DIRS=...
7 years 2 months ago #708 by Guosheng Fu
I have
ZLIB_INCLUDE_DIR:PATH=/gpfs/runtime/opt/zlib/1.2.8
//No help, variable specified on the command line.
ZLIB_LIBRARY:UNINITIALIZED=/gpfs/runtime/opt/zlib/1.2.8/lib
But I don't have
ZLIB_LIBRARY_DEBUG
or
