Solving advection equation on domain split in two
7 years 3 months ago #674 by rhebergens
I am trying to solve the advection equation (with advective velocity b=(0,-1)) on a domain that has been split in two subdomains. To split the domain, I'm using the code previously made available by Guosheng, see:
ngsolve.org/forum/ngspy-forum/114-interface-integrals#491
What I would like to do, is solve the advection equation on the whole domain. As initial test case I use as initial condition that u=1 and the inflow condition is 1 so that the solution must be 1 for the whole simulation. This is not happening. Instead, on half the domain the solution is equal to 1 and on the other half the solution eventually tends to u=0.5. I think this has to do with the call to u.Other() on the interface between the two subdomains. I attach my code. Do you have any suggestions how to fix this issue?
Thanks!
Sander
7 years 3 months ago #676 by joachim
Hi Sander,
for the explicit part it is working like this:
If there is a neighbouring volume element, the .Other refers to that. Thus, internal interfaces are ignored. You can use a GridFunction from a FacetFESpace to add source terms on internal edges (see attached file).
for the implicit part - I don't know. Use HDG !!!
best, Joachim
7 years 3 months ago #684 by rhebergens
Hi Joachim,
Thanks for the suggestion. HDG indeed does the job. Attached the code using HDG.
Thanks,
Sander
