- Thank you received: 31
PIP installers available!
3 years 7 months ago - 3 years 7 months ago #4222
by matthiash
Dear NGSolve users,
Finally we managed to provide pip-installers for our software. This means, installing NGSolve on your computer now becomes as easy as py!
pip install ngsolve
For Linux, we also provide an ngsolve-avx2 package which is compiled using AVX2 instructions (only working on supported hardware).
Also nightly builds will be provided (use the --pre flag of pip to install prerelease versions).
Similar to the conda installers, run-time code generation is currently not supported on all platforms, but we are working on it.
The NGSolve Team
PIP installers available! was created by matthiash
Dear NGSolve users,
pip install ngsolve
The NGSolve Team
test
Last edit: 3 years 7 months ago by matthiash.
The following user(s) said Thank You: paul.stocker, alex.v
3 years 7 months ago #4236
by matthiash
Replied by matthiash on topic PIP installers available!
Some people reported problems starting Python after installing the ngsolve pip-package on MacOS, and after rebooting. Updating ngsolve to the NGSolve-6.2.2202 release solves the problem.
If pip is also not working (because of this problem), you can manually delete the directory /Library/Frameworks/Python.framework/Versions/3.10/Contents ( change 3.10 to your python version).
The error message you get, when having this problem looks like this:
dyld[3600]: Library not loaded: /Library/Frameworks/Python.framework/Versions/3.10/Python
Referenced from: /Library/Frameworks/Python.framework/Versions/3.10/bin/python3.10
Reason: tried: '/Library/Frameworks/Python.framework/Versions/3.10/Python' (code signature invalid (errno=1) sliceOffset=0x004B0000, codeBlobOffset=0x00483BA0, codeBlobSize=0x000135F0 for
3 years 6 months ago #4283
by alex.v
Replied by alex.v on topic PIP installers available!
I am having issues with installing it through pip on Ubuntu 21.10. It does not seem to install with umfpack, something that the apt version did.
Running the following line ```a_assembled.mat.Inverse(freedofs=freedofs, inverse="umfpack")``` works with the apt version, but crashes the pip installation.
Is this an oversight, a temporary limitation, or a permanent limitation of the pip install?
Additionally, this page shows the default CMake options when building from source. Is there a list to show which options are enabled for the different distribution modes (pip, apt, conda, etc.) of NGSolve?
3 years 5 months ago #4367
by alex.v
Any update on this?
- paul.stocker
2 years 11 months ago - 2 years 11 months ago #4542
by paul.stocker
Replied by paul.stocker on topic PIP installers available!
Hi everyone!
I tried the pip installer on windows with anaconda
Running the conda environement
conda create -n test python=3.9
I gave pip install ngsolve a try. The install works, even netgen opens a gui, but ngsolve cannot find ngslib.
(EDIT: I tried without conda and got the same result.)
from .ngslib import __version__, ngstd, bla, la, fem, comp, solve
ImportError: DLL load failed while importing ngslib: The specified module could not be found.
I tried to add everything to PATH and PYTHONPATH by hand without success. I uploaded the output of conda info --system here
I also tried
conda install -c ngsolve ngsolve
but could not find a python version that would satisfy the specifications. I tried python3.9 giving
- ngsolve -> python[version='>
.7,
.8.0a0|>
.8,
.9.0a0']
so I tried python3.7 telling me
- ngsolve -> python[version='>=2.7,<2.8.0a0|>
.6,
.7.0a0|>
.10,
.11.0a0|>
.9,
.10.0a0']
Any hints to get this working?
Cheers,
Paul
I also tried
Cheers,
Paul
Last edit: 2 years 11 months ago by paul.stocker.
- maurosgroi
2 years 10 months ago #4557
by maurosgroi
Replied by maurosgroi on topic PIP installers available!
Dear Developers,
I am facing the very same problems described by paul.stocker .
Which version of Anaconda should we use?
Is there a workaround to solve the problem?
Thanks a lot and best regards,
Mauro Sgroi.
Mauro Sgroi.
