- Thank you received: 6
How to access CreateSmoothingBlocks from python for fes?
- Guosheng Fu
- Topic Author
- Elite Member
3 years 10 months ago #3442
by Guosheng Fu
I am trying to use the "many" default smoothing blocks implemented for finite element spaces for preconditioning.
So I tried to export CreateSmoothingBlocks for a finite element space (EdgeFESpace is "exactly" your NedelecFESpace), with
But when I call
python complains:
I didn't find a solution to this in the source files. Can you help with this?
Guosheng
ExportFESpace<EdgeFESpace> (m, "EdgeFESpace")
.def("CreateSmoothingBlocks", [](shared_ptr<EdgeFESpace> self, int type) {
return self->CreateSmoothingBlocks(type);
py::arg("type"), "create smoothing block for this type")
But when I call
fes.CreateSmoothingBlocks(0)
TypeError: Unable to convert function return value to a Python type! The signature was
(self: xfem.ngsxfem_py.EdgeFESpace, type: int) -> ngcore::Table<int, unsigned long>
Guosheng
3 years 10 months ago #3453
Replied by christopher on topic How to access CreateSmoothingBlocks from python for fes?
This means that the class Table<int, unsigned long> doesn't have a Python equivalent (=export). You can either export the table or convert the table first to some Python object (for example a list of lists).
- Guosheng Fu
- Topic Author
- Elite Member
3 years 10 months ago #3456
by Guosheng Fu
Replied by Guosheng Fu on topic How to access CreateSmoothingBlocks from python for fes?
Yes. I noticed that the python list will then be converted back to Table <int, unsigned long> in the CreateBlockSmoother class.
But, I haven't found a way to convert the Table<int, ...> class back to python list back. I don't know how to create a python list in C++.
3 years 10 months ago - 3 years 10 months ago #3458
Something like
should work.
But you could as well just export the Table and write another python constructor for the smoother to be constructed with a table, then you don't have to copy
py::list pytable;
for(const auto& row : table)
pytable.append(MakePyList(row));
Last edit: 3 years 10 months ago by christopher.
- Guosheng Fu
- Topic Author
- Elite Member
3 years 10 months ago #3460
by Guosheng Fu
Thanks, Christopher. This works.
I need to change the loop to
as table is a smart pointer from CreateSmoothingBlocks.
The code works much faster now.
So, there is basically no difference from the python end whether the block is a list of lists or a list of sets (which we use to generate the blocks in the python script) because they will simply be converted to the Table<int> type in CreateBlockSmoother, right?
for(const auto& row : *table)
- Guosheng Fu
- Topic Author
- Elite Member
3 years 10 months ago #3461
by Guosheng Fu
To create a new python BlockSmoother constructor that takes the table as input seems the fastest approach, but then I need to modify the source file in linalg/python_linalg.cpp, which is a bit of a headache for me. (if you could include this in later ngsolve versions, that would be great
Currently I am simply adding "new" fespaces/classes in a separate project, which I feel a little bit safer as I don't need to directly touch the git source files.
