Solving Hyperleasticity: Correctly defining boundaries
- bhaveshshrimali
- Junior Member
4 years 11 months ago #3333
by bhaveshshrimali
Replied by bhaveshshrimali on topic Solving Hyperleasticity: Correctly defining boundaries
Thanks Michael,
Indeed it's mu/2., I somehow forgot to update it here.
I will take a careful look today at the problem definition and bc's more carefully today.
The source of the above exercise is the FEniCS demo on hyperelasticity:
fenicsproject.org/docs/dolfin/latest/pyt...erelasticity.py.html
I have implemented the above problem by myself using pure-NumPy too, so I will check further why this has problems converging...
from math import pi as myPi
mesh = Mesh(unit_cube.GenerateMesh(maxh=0.06))
V = VectorH1(mesh, order=1, dirichlet="back|front")
print(mesh.GetBoundaries())
u, v = V.TnT()
# material parameters and forces
E, nu = 10.0, 0.3
mu = E / 2./(1+nu)
lmbda = 2 * mu * nu/(1-2*nu)
bodyForce = CoefficientFunction((0., -0.5, 0.))
# Define strain measures
I = Id(mesh.dim)
F = I + grad(u)
# help(F)
I1 = Trace(F.trans * F)
J = Det(F)
psi = mu/2. * (I1 - 3.) - mu * log(J) + lmbda/2. * (J - 1.0)**2
# S = mu * F - mu * (F.trans).Inv + lmbda * J * (J - 1.0) * (F.trans).Inv
# definition of bilinear and linear forms
a = BilinearForm(V, symmetric=False)
a += Variation(psi.Compile() * dx)
a += Variation((-1 * InnerProduct(bodyForce, u)).Compile() * dx)
u = GridFunction(V)
u.vec[:] = 0.
# definition of the boundaries
scale = 0.5
yo, zo = 0.5, 0.5
thta = myPi/3.
factor=Parameter(1.0)
uLeft = CoefficientFunction((0.0, 0., 0.))
uRight = CoefficientFunction((
0.,
scale * (yo + (y - yo) * cos(thta) - (z - zo) * sin(thta) - y),
scale * (zo + (y - yo) * sin(thta) + (z - zo) * cos(thta) - z)
u.Set(mesh.BoundaryCF({"back" : uLeft, "front" : x*uRight}), definedon=mesh.Boundaries("back|front"))
res = u.vec.CreateVector()
w = u.vec.CreateVector()
maxiters = 20
a.Apply(u.vec, res)
a.AssembleLinearization(u.vec)
inv = a.mat.Inverse(V.FreeDofs(), inverse="sparsecholesky")
w.data = inv * res
resNorm = sqrt(abs(InnerProduct(w, w)))
u.vec.data -= w
iter = 0
while resNorm > 1.e-8 and iter < maxiters:
a.Apply(u.vec, res)
w.data = inv * res
print(f"Norm: {resNorm}")
u.vec.data -= w
iter += 1
Draw(u, mesh, "displacement")
- bhaveshshrimali
- Junior Member
4 years 11 months ago #3337
by bhaveshshrimali
So Newton indeed converges for a smaller mesh/problem, but fails on a reasonable mesh (65k elements). Unless I am doing something fundamentally wrong in NGSolve, I would expect that this should converge...
And to add, the exact same mesh when run with dolfin, converges in 5 iterations. I would try and assemble the linearized system instead of using the NewtonSolver class in Dolfin, but I expect that it would converge then too:
Here is the code:
Dolfin code:
Newton iterations: NGSolve
Newton Iterations: Dolfin
Here is the code:
# for i in range(2):
# mesh.Refine()
V = VectorH1(mesh, order=2, dirichlet="back|front")
u, v = V.TnT()
E, nu = 10.0, 0.3
mu = E / 2./(1+nu)
I = Id(mesh.dim)
F = I + grad(u)
# help(F)
J = Det(F)
factor=Parameter(1000.0)
# a += Variation((0.5/factor * InnerProduct(grad(u), grad(u))).Compile() * dx)
u = GridFunction(V)
u.vec[:] = 0.
scale = 0.5
yo, zo = 0.5, 0.5
thta = myPi/3.
0.,
# resNew = u.vec.CreateVector()
maxiters = 50
a.Apply(u.vec, res)
inv = a.mat.Inverse(V.FreeDofs(), inverse="pardiso")
w.data = inv * res
u.vec.data -= w
iter = 0
factor.Set(1.e6)
a.Apply(u.vec, res)
w.data = inv * res
u.vec.data -= w
iter += 1
Draw(u, mesh, "displacement", deformation=True)
Dolfin code:
import numpy as np, meshio
from dolfin import *
def generateMesh():
msh = unit_cube.GenerateMesh(maxh=0.05)
msh.Export("netgenMesh.msh", "Gmsh2 Format")
mesh = meshio.read("netgenMesh.msh")
points, cells = mesh.points, np.vstack([cell.data for cell in mesh.cells if cell.type == "tetra"])
meshio.xdmf.write("netGenMesh.xdmf", meshio.Mesh(points, cells = {"tetra": cells}))
return 1
generateMesh()
mesh = Mesh()
XDMFFile("netGenMesh.xdmf").read(mesh)
# mesh = UnitCubeMesh(24, 16, 16)
class Problem(NonlinearProblem):
def __init__(self, J, F, bcs):
self.bilinear_form = J
self.linear_form = F
self.bcs = bcs
NonlinearProblem.__init__(self)
def F(self, b, x):
assemble(self.linear_form, tensor=b)
for bc in self.bcs:
bc.apply(b, x)
def J(self, A, x):
assemble(self.bilinear_form, tensor=A)
for bc in self.bcs:
bc.apply(A)
E, nu = Constant(10), Constant(0.3)
mu = E/2./(1+nu)
lmbda = 2*mu*nu/(1-2*nu)
V = VectorFunctionSpace(mesh, "CG", 1)
u = Function(V)
u_ = TrialFunction(V)
v = TestFunction(V)
bodyForce = as_vector([0, -0.5, 0])
surFaceTraction = as_vector([0.1, 0., 0.])
left = "near(x[0], 0) && on_boundary"
right = "near(x[0], 1) && on_boundary"
rightBoundary = Expression((
"0.0",
"(0.5 + (x[1] - 0.5) * cos(pi/3) - (x[2] - 0.5) * sin(pi/3) - x[1])/2.",
"(0.5 + (x[1] - 0.5) * sin(pi/3) + (x[2] - 0.5) * cos(pi/3) - x[2])/2."
), pi=np.pi, degree=2)
bcs = [
DirichletBC(V, Constant((0,0,0)), left),
DirichletBC(V, rightBoundary, right)
F = Identity(len(u)) + grad(u)
I1 = inner(F, F)
J = det(F)
psi = mu/2. * (I1-3) - mu * ln(J) + lmbda/2 * (J-1)**2
pi = derivative(psi, u, v) * dx - inner(bodyForce, v) * dx - inner(surFaceTraction, v) * ds
Jac = derivative(pi, u, u_)
problem = Problem(Jac, pi, bcs)
solver = NewtonSolver()
solver.solve(problem, u.vector())
from vedo.dolfin import plot as vplot
vplot(u, mode="displaced mesh")
Norm: 6298.188667502683
Norm: 16417474.934260502
Norm: 5484205427.2328205
Norm: 216770135728.68326
File ".\hyperelasticityDolfin.py", line 74, in <module>
KeyboardInterrupt
Newton iteration 0: r (abs) = 4.895e+00 (tol = 1.000e-10) r (rel) = 1.000e+00 (tol = 1.000e-09)
Newton iteration 1: r (abs) = 1.295e-01 (tol = 1.000e-10) r (rel) = 2.646e-02 (tol = 1.000e-09)
Newton iteration 2: r (abs) = 1.470e-02 (tol = 1.000e-10) r (rel) = 3.004e-03 (tol = 1.000e-09)
Newton iteration 3: r (abs) = 1.394e-03 (tol = 1.000e-10) r (rel) = 2.848e-04 (tol = 1.000e-09)
Newton iteration 4: r (abs) = 7.730e-06 (tol = 1.000e-10) r (rel) = 1.579e-06 (tol = 1.000e-09)
Newton iteration 5: r (abs) = 1.394e-09 (tol = 1.000e-10) r (rel) = 2.847e-10 (tol = 1.000e-09)
Newton solver finished in 5 iterations and 5 linear solver iterations.
- mneunteufel
- Premium Member
- Thank you received: 59
4 years 11 months ago #3338
by mneunteufel
Replied by mneunteufel on topic Solving Hyperleasticity: Correctly defining boundaries
Hi bhaveshshrimali,
when looking at the very first update the increment seems to overshoot such that Newton is not able any more to find the correct solution. I guess this is induced by the boundary conditions. Maybe Dolfin handles boundary conditions differently than NGSolve and thus converges easier.
The most simple adaption is to use a damped Newton to avoid the overshooting. You can use the build in Newton solver to play around with damping factors:
Another possibility is to solve a linear elasticity problem with the given boundary data and hope that the result gives an initial guess without inducing overshooting behaviour.
Attached you'll find your code with the Newton damping (and some little changes).
solvers.Newton(a, u, dampfactor=0.25, maxit=maxiters, maxerr=1.e-8, printing=True)
- bhaveshshrimali
- Junior Member
4 years 11 months ago #3341
by bhaveshshrimali
Thanks a lot Michael! It seems a rather peculiar example to try. I will try another simpler hyperelasticity problem (simpler in terms of the boundary conditions)
I had a question: does NGSolve use all threads by default? Can I control the number of threads in command line usage? I am working on a Windows laptop.
Bhavesh
Bhavesh
- mneunteufel
- Premium Member
4 years 11 months ago #3343
by mneunteufel
To assemble bilinearforms or invert matrices in parallel you need to activate the TaskManager. Then NGSolve uses all Threads per default. To limit the maximal threads you can use the SetNumThreads function or the NGS_NUM_THREADS environment variable, see also this
tutorial
If you use umfpack/pardiso you might need additional commands. For Linux I set the environment variables MKL_NUM_THREADS and OMP_NUM_THREADS.
The following user(s) said Thank You: bhaveshshrimali
