Solving Hyperleasticity: Correctly defining boundaries
4 years 11 months ago #3324 by bhaveshshrimali
Hi everyone,
I was trying to translate the hyperelasticity example from FEniCS to ngsolve, following the nonlinear elasticity tutorial, and Navier Stokes tutorial to implement homogenous and non-homogenous dirichlet boundary conditions on different parts of the boundary.
However, it seems that the boundary conditions are not getting assigned properly (looking at the GUI). Would anyone be able to help me pin down the error? You can see from the norm of the error, that it does not converge.
import netgen.gui from math import pi as myPi from ngsolve import * from netgen.csg import unit_cube mesh = Mesh(unit_cube.GenerateMesh(maxh=0.1)) V = VectorH1(mesh, order=1, dirichlet="left|right") u = GridFunction(V, str="u") u.vec[:] = 0. du, v = V.TnT() # material parameters and forces E, nu = 10.0, 0.3 mu = E / 2./(1+nu) lmbda = 2 * mu * nu/(1-2*nu) bodyForce = CoefficientFunction((0, -0.5, 0.)) # definition of the boundaries scale = 0.5 yo, zo = 0.5, 0.5 thta = myPi/3. uLeft = CoefficientFunction((0., 0., 0.)) uRight = CoefficientFunction(( 0., scale * (yo + (y - yo) * cos(thta) - (z - zo) * sin(thta) - y), scale * (zo + (y - yo) * sin(thta) + (z-zo) * cos(thta) - z) )) u.Set(uLeft, definedon=mesh.Boundaries("left")) u.Set(uRight, definedon=mesh.Boundaries("right")) # Define strain measures I = Id(mesh.dim) F = I + grad(du) I1 = Trace(F.trans * F) J = Det(F) psi = mu * (I1 - 3) - mu * log(J) + lmbda/2. * (J-1)**2 # definition of bilinear and linear forms a = BilinearForm(V, symmetric=False) a += Variation(psi.Compile() * dx) a += Variation((-1 * InnerProduct(bodyForce, du)).Compile() * dx) # create the residual and iteration vectors res = u.vec.CreateVector() w = u.vec.CreateVector() resNorm = 1.0 while resNorm > 1.e-8: a.Apply(u.vec, res) a.AssembleLinearization(u.vec) inv = a.mat.Inverse(V.FreeDofs()) w.data = inv * res resNorm = InnerProduct(w, res) print(f"Norm: {resNorm}") u.vec.data -= w Draw(u, mesh, "displacement") SetVisualization(deformation=True)
gives
Norm: 6.686688205442815 Norm: 0.49337768606525656 Norm: 0.34295300814873925 Norm: 0.15001895765763176 Norm: 0.06517533253371934 Norm: 0.019404532237654374 Norm: 0.18895838479738908 Norm: 2.024789522475844 Norm: 5815.697445306668 Norm: 49695.17791867306 Norm: 58282.3479021152 Norm: 11584203088583.24 Norm: 2.3448080388890567e+22 Norm: 3.154397165784633e+26 Norm: 8.26906306359288e+25 Norm: 2.167685693089545e+25 Norm: 5.682457983539969e+24
4 years 11 months ago - 4 years 11 months ago #3325 by christopher
u.Set(cf, definedon=...)
sets u to cf on the definedon part and to 0 everywhere else, set the boundary values like this:
u.Set(mesh.BoundaryCF({"left" : uLeft, "right" : uRight}), definedon=mesh.Boundaries("left|right"))
Last edit: 4 years 11 months ago by christopher.
4 years 11 months ago #3328 by bhaveshshrimali
Thanks Christopher!
Is this a newer feature? NGSolve-6.2.1909 does not seem to have it. I will try updating NGSolve to the latest version and test it again...
AttributeError: 'ngsolve.comp.Mesh' object has no attribute 'BoundaryCF'
4 years 11 months ago #3329 by bhaveshshrimali
Ok this works with the newer version. But even with the newer version (NGSolve-6.2.2009), I get a diverging Newton.
Norm: 2.6808208867801797 Norm: 577.2816648847577 Norm: 152009.87301735353 Norm: 7366462.124902223 Norm: 65416518034032.02 Norm: 5.554793589592823e+16 Norm: 1.4678499972939826e+16 Norm: 3848066201629095.0 Norm: 1008756719615877.0 Norm: 264477504711945.2
I will take a look at implementing non-homogenous BC's more carefully.
4 years 11 months ago #3331 by bhaveshshrimali
After inspecting a bit more the location of the boundaries "left", "right", ... I noticed that the boundaries that I need (x=0 and x=1) correspond to "back" and "front". Indeed after replacing them accordingly and applying the boundary condition in steps, rather than at once, the solution seems to be reasonable till a point, and then it diverges:
for i in range(1, 11): factor.Set(i/10) u.Set(mesh.BoundaryCF({"back" : uLeft, "front" : uRight}), definedon=mesh.Boundaries("back|front")) print(i) resNorm = 1.0 iter = 0 while resNorm > 1.e-8 and iter < maxiters: a.Apply(u.vec, res) a.AssembleLinearization(u.vec) inv = a.mat.Inverse(V.FreeDofs()) w.data = inv * res resNorm = sqrt(abs(InnerProduct(w, w))) print(f"Norm: {resNorm}") u.vec.data -= w iter += 1 Draw(u, mesh, "displacement") SetVisualization(deformation=True)
gives
1 Norm: 0.840274935028221 Norm: 0.010631338197297788 Norm: 2.840043781994656e-05 Norm: 5.625360578002826e-10 2 Norm: 1.3145809712371617 Norm: 0.03864670201207834 Norm: 0.0003690373463827511 Norm: 8.934665769419485e-08 Norm: 1.54388135479357e-14 3 Norm: 1.8523594043744418 Norm: 0.08405462602954474 Norm: 0.0018541634265310004 Norm: 1.9279392913312044e-06 Norm: 8.193550778213933e-12 4 Norm: 2.4123885921399872 Norm: 0.14726391288538263 Norm: 0.0060619644879045765 Norm: 1.9854480113520826e-05 Norm: 1.1251011825818185e-09 5 Norm: 2.816514170226768 Norm: 0.4758279175877349 Norm: 0.07470240485416736 Norm: 0.14433503658998675 Norm: 0.2576930420365274 Norm: 0.15947077282736843 Norm: 0.04193568718574943 Norm: 0.04151801466555532 Norm: 0.0044976089152604015 Norm: 5.306089515763066e-05 Norm: 8.324583871537812e-09 6 Norm: 4.623385880239417 Norm: 2.913358091896825 Norm: 2.617097160078447 Norm: 2.9116418166392988 Norm: 6.296120155081865 Norm: 12.355324294951478 Norm: 19.201276563870323 Norm: 58.62691253475249 Norm: 230.766474679662
I think, this is due to inaccurate approximation of the jacobian in automatic differentiation of the residual. I don't see any other reason on why Newton wouldn't converge after a point for this problem. I checked the deformation and it seems reasonable till the 6th loading step.
4 years 11 months ago #3332 by mneunteufel
Hi bhaveshshrimali,
are you sure your material law is correct? For zero external forces and zero Dirichlet boundary condition the identity function is not the trivial solution. For the Neo-Hookean material law mu/2 should be the correct scaling for the first term:
psi = mu/2 * (I1 - 3) - mu * log(J) + lmbda/2. * (J-1)**2
By setting the boundary conditions for every loadstep you reset your solution rather than using the solution of the previous loadstep as starting point for the next one. I would suggest to set the boundary conditions only at the beginning:
u.Set(mesh.BoundaryCF({"back" : uLeft, "front" : uRight}), definedon=mesh.Boundaries("back|front")) for i in range(1, 11): factor.Set(i/10) ...
The boundary condition at the right boundary is quite large. As on the opposite boundary you have zero Dirichlet condition you can set them by
u.Set(x*uRight)
which will provide a better initial guess helping Newton to converge.
The following user(s) said Thank You: bhaveshshrimali
