Writing the meshes as BREP file or MSH file using python api
4 years 11 months ago #3307
by renard
I'm trying to create a simple geometry of a fusion of two spheres using the python api of netgen.
Going through the tutorials I have written the following code,
This code is working, however I would like to save this in a 'brep' file or 'msh3' file ( gmsh file format).
Is there any way to do this ?
also, this "vol" file format can not be opened by Netgen. Is there any way to open and visualize the saved 'vol' file later ?
Thanks for your help.
sphere1 = Sphere( Pnt(0,0,0), 12.0 )
sphere2 = Sphere( Pnt(20,0,0), 12.0 )
geo.Add( sphere1 + sphere2 )
mesh = geo.GenerateMesh(maxh = 1.0)
mesh.Save("twospheres.vol")
4 years 11 months ago #3308
by hvwahl
Replied by hvwahl on topic Writing the meshes as BREP file or MSH file using python api
Hello renard,
checkout this forum thread about exporting the mesh to other file formats. Essentially you need to do
I had no issue opening the mesh in the netgen gui via File > Load Mesh. One alternative to visualise the mesh via ngsolve would be to export a vtk with the constant 1 as the CoefficientFunction and then to visualise this in Paraview.
Best wishes
Henry
mesh.Export(filename, format)
Best wishes
Henry
The following user(s) said Thank You: renard
4 years 11 months ago #3309
by cwinters
Replied by cwinters on topic Writing the meshes as BREP file or MSH file using python api
Hi renard,
to load the Netgen mesh from python, you have to do the following
To export the mesh, use the function suggested by Henry.
from netgen import meshing
m = meshing.Mesh(3) # create a 3-dimensional mesh
m.Load("twospheres.vol")
4 years 11 months ago #3311
by renard
Replied by renard on topic Writing the meshes as BREP file or MSH file using python api
Hi, Thank you. I could export the mesh in Gmsh2 file format. However, I could not find the option to save the geometry as a boundary-representation (brep) file. Can you help me with that too?
Time to create page: 0.176 seconds
