Exporting mesh using a sript
8 years 1 month ago #193 by Nils
Hello together,
I would like to export a mesh, generated in netgen, using a script command. Basically I would like to circumvent clicking on "File"->"Export Mesh" .
Is there any command I can add to my Python script?
Tank you and best regards,
Nils
8 years 1 month ago #194 by christopher
The netgen mesh has a method "Export" which takes a filename and a format.
The following user(s) said Thank You: Nils
8 years 1 month ago #195 by Nils
Replied by Nils on topic Exporting mesh using a sript
Thank you for your fast reply,
but unfortunately it does not solve my problem. The mesh I am using is a ngsolve mesh and therein I cannot find a method "Export" or something related. Is it possible to simply convert the ngsolve mesh to a netgen type mesh or to add the export method to ngsolve?
8 years 1 month ago #196 by schruste
Hi Nils,
The NGsolve mesh has a member ngmesh which gives you access to the netgen mesh.
Try mesh.ngmesh.Export...
8 years 1 month ago #197 by Nils
Now it works as looked-for.
Thanks for your help Christoph and Christopher
