- Thank you received: 108
problems with the docs
5 years 3 weeks ago #3189
Replied by joachim on topic problems with the docs
looks like you have an elder version of NGSolve, these are all quite new features
you can print the active version via
current version is 2008
in the online documentation you can choose the ngsolve-version at the bottom of the menu on the left.
print (ngsolve.__version__)
5 years 3 weeks ago #3190
by Poulin
Replied by Poulin on topic problems with the docs
Thank you for the help.
When I am in a notebook and I type the line that you suggested, after importing ngsolve, I get an error
NameError Traceback (most recent call last)
<ipython-input-13-33901d1e5014> in <module>
1 from ngsolve import *
----> 2 print (ngsolve.__version__)
NameError: name 'ngsolve' is not defined
However, when I am in the terminal and typ in netgen I see I'm using a very old version,
$ netgen
NETGEN-6.2.2007
togl-version : 2
OCC module loaded
loading ngsolve library
NGSolve-6.2.2007
Using Lapack
Running parallel using 36 thread(s)
importing NGSolve-6.2.2007
This is what installed in ubuntu usin apt-get.
To get a newer version do you recommend I build them from source?
$ netgen
NETGEN-6.2.2007
togl-version : 2
OCC module loaded
NGSolve-6.2.2007
Using Lapack
5 years 3 weeks ago #3191
by Poulin
To get the latest version I decided to build from source. Everything seemed to go well until it was scannin gdependencies of target ngstd, and that's where it failed because of an error. Should I post this until a different problem?
Scanning dependencies of target ngstd
[ 1%] Building CXX object ngstd/CMakeFiles/ngstd.dir/blockalloc.cpp.o
In file included from /home/fpoulin/software/ngsolve-src/ngstd/ngstd.hpp:14,
from /home/fpoulin/software/ngsolve-src/ngstd/blockalloc.cpp:12:
/home/fpoulin/software/ngsolve-src/include/ngs_stdcpp_include.hpp:43:2: error: #error "GCC 9.1/9.2 generates wrong code on AVX512 platforms (see gcc.gnu.org/bugzilla/show_bug.cgi?id=93009 ). Either build for a different architecture (cmake -DUSE_NATIVE=OFF), or use a different compiler (like GCC 8.3 or Clang)"
43 | #error "GCC 9.1/9.2 generates wrong code on AVX512 platforms (see gcc.gnu.org/bugzilla/show_bug.cgi?id=93009 ). Either build for a different architecture (cmake -DUSE_NATIVE=OFF), or use a different compiler (like GCC 8.3 or Clang)"
make[5]: *** [ngstd/CMakeFiles/ngstd.dir/build.make:63: ngstd/CMakeFiles/ngstd.dir/blockalloc.cpp.o] Error 1
make[4]: *** [CMakeFiles/Makefile2:173: ngstd/CMakeFiles/ngstd.dir/all] Error 2
make[3]: *** [Makefile:141: all] Error 2
make[2]: *** [CMakeFiles/ngsolve.dir/build.make:116: dependencies/Stamp/ngsolve/ngsolve-build] Error 2
make[1]: *** [CMakeFiles/Makefile2:222: CMakeFiles/ngsolve.dir/all] Error 2
make: *** [Makefile:152: all] Error 2
5 years 3 weeks ago #3192
by matthiash
Replied by matthiash on topic problems with the docs
Concerning the apt-get version: Which Ubuntu version do you have? Note that 19.10 is already end-of-life and not receiving updates anymore.
Concerning the compiler error: Your compiler version is buggy, that's why we had to explicitly block it. One way to work around it, is configuring cmake with
-DUSE_NATIVE_ARCH=OFF
which results in sub-optimal performance of the generated code (no AVX instructions used).
I think both of your issues could be solved by an Ubuntu upgrade.
5 years 3 weeks ago #3193
by Poulin
Thank you Matthias.
I will certainly get my ubuntu machine upgraded.
For the moment I have used the configuration that you suggested and have been able to install version 6.2.2008 with success. I admit that the instructions I found in the docs did not quite work in setting up the PYTHONPATH but I figured out what it should be so I'm happy about that.
I can also verify that the Maxwells example does work, and I suspect the others will work as well.
Thanks everyone for the help!
