problems with the docs
5 years 3 weeks ago #3178
by Poulin
problems with the docs was created by Poulin
I am brand new to ngsolve but installed it today and and keen to learn to use it. There are a couple of problems that I found in the docs and I am not sure if it is well known or not.
First, in installing ngsolve on jupyter on my ubuntu system, I needed to install jupyter-notebook as well, and the install command did not work but needed to use enable, as copied below.
sudo apt install jupyter-notebook
jupyter nbextension enable ngsolve --user --py
Second, I found about 6 or so examples in the notebooks that did not run, the first of which was the notebook on Maxwells equations. I can provide a longer list if need be.
I presume these are known but wanted to try and contribute in case they aren't.
5 years 3 weeks ago #3179
Replied by joachim on topic problems with the docs
Hi Poulin,
welcome to NGSolve. Yes, please tell us what is not working.
You may also watch the tutorials on youtube to see how they should work, e.g. the Maxwell tutorial:
5 years 3 weeks ago #3185
by Poulin
Replied by Poulin on topic problems with the docs
Hello Joachim,
Thanks for sharing this video wtih me.
I understand the setup of the code but the problem I had was with an error.
In particular, I am copying the error message below. I will copy other errors that I get in the other codes in separate lines.
AttributeError Traceback (most recent call last)
<ipython-input-5-47895662d752> in <module>
5 from math import pi
6 mu0 = 4*pi*1e-7
----> 7 mur = mesh.MaterialCF({"magnet" : 1000}, default=1)
8
9 a = BilinearForm(fes)
AttributeError: 'ngsolve.comp.Mesh' object has no attribute 'MaterialCF'
6 mu0 = 4*pi*1e-7
8
5 years 3 weeks ago #3186
by Poulin
2.6 Stokes Equation
<ipython-input-2-4cfe5b119a48> in <module>
1 V = H1(mesh, order=2, dirichlet="wall|inlet|cyl")
2 Q = H1(mesh, order=1)
----> 3 X = V*V*Q
TypeError: unsupported operand type(s) for *: 'ngsolve.comp.H1' and 'ngsolve.comp.H1'
----> 3 X = V*V*Q
5 years 3 weeks ago #3187
by Poulin
2.11 Matrix free operator application¶
NameError Traceback (most recent call last)
<ipython-input-4-8901926dddb7> in <module>
2 felS = Sigma.GetFE(el)
3 felV = V.GetFE(el)
----> 4 fel = MixedFE(felS, felV)
5 trafo = mesh.GetTrafo(el)
6
NameError: name 'MixedFE' is not defined
6
5 years 3 weeks ago #3188
by Poulin
3.3 Discontinuous Galerkin Discretizations for linear transport
<ipython-input-11-05fb163505bf> in <module>
1 # this does not work:
2 c2 = BilinearForm(VT)
----> 3 res.data = c2.mat * gfu.vec
TypeError: matrix not ready - assemble bilinearform first
