proper environment setup for MPI in jupyter notebook
5 years 4 months ago #2830 by Guosheng Fu
How to properly set up jupyter notebook so that I can use MPI there? I couldn't find a solution online.
For python, we simply preload the library using the ngspy hack:
LD_PRELOAD=... pythonr $*
Can we do the same thing for jupyter notebook?
Guosheng
5 years 4 months ago - 5 years 4 months ago #2832 by lkogler
Are you really sure this is something you absolutely want to do?
As far as the preloads are concerned, If you set the LD_PRELOAD from ngspy as an environment variable it should work. But that will not yet allow you to run MPI parallel jupyter notebooks - the jupyter notebook spawns a python instance in the background, and you want THAT to be parallel, not the notebook itself.
I have managed to set something like this up in the past using jupyter clusters, but is is very finicky and a bit unstable.
You can look into jupyter clusters and have a look at the MPI jupyter notebooks from the 2nd user meeting if you want to give it a try. I can also give you the ipyparallel config files I used back then if you want.
Lukas
Last edit: 5 years 4 months ago by lkogler.
5 years 4 months ago #2834 by Guosheng Fu
Hi Lukas,
Looks very complicated to do... ;<
I am doing jupyter only for education purpose. I just want to show the petsc amg preconditioner from the ngs-petsc library, which needs MPI to start with.
Currently, I simply go back to the plain python code to do the demo.
Can you walk me thought the setup? :>
Guosheng
5 years 4 months ago #2835 by lkogler
The petsc-amg preconditioner needs an NGSolve version that is compiled with MPI, but it does not require you to actually run in parallel.
If you want to use this in a sequential run (but an MPI version), just setting the LD_LIBRARY_PATH should do it. It only gets complicated when you want multiple MPI ranks.
If this does not work for some reason, a workaround would be to manually load the libraries from the ngspy script at the top of your jupyter notebook. Have a look at CDLL from the ctypes python module.
Lukas
5 years 4 months ago #2839 by Guosheng Fu
I just want to use the preconditioner in serial.
Setting LD_LIBRARY_PATH in my bashrc file does not work.
Can you give me a demo on manual load via ngspy?
CDLL and ctypes in python are foreign language to me. I am afraid dig into that.
5 years 4 months ago - 5 years 4 months ago #2848 by lkogler
Put something like this at the top of the jupyter notebook
from ctypes import CDLL, RTLD_GLOBAL # these are the libraries that are preloaded by ngspy, we can replace all the MKL libraries by # the runtime library libmkl_rt libs = ["/home/lkogler/local/openmpi-3.1-gcc-8.1/lib/libmpi.so", "/opt/intel/mkl/lib/intel64/libmkl_rt.so"] for lib in libs: CDLL(lib, RTLD_GLOBAL) from ngsolve import *
Generally, I have found that you really only need to preload the libmkl_rt library when you do it this way.
Lukas
