SIGSEGV fault for large problems
5 years 6 months ago #2442
by gcdiwan
Ok, so the version of C or Fortran compiler used for MUMPS has no effect and it's just the openmpi that has to be compiled with gcc 8.3.0?
Replied by gcdiwan on topic SIGSEGV fault for large problems
JuliusZ wrote: I can confirm this issue.
I had the same problem and compiling openmpi with gcc 8.3.0 fixed it.
5 years 6 months ago - 5 years 6 months ago #2443
by JuliusZ
Replied by JuliusZ on topic SIGSEGV fault for large problems
well, gcc contains a c (gcc) and fortran (gfortran) compiler. Ideally, everything is compiled with the same version. You can also set this by the environment variables CC, CXX, and FC for cmake.
Last edit: 5 years 6 months ago by JuliusZ.
5 years 6 months ago - 5 years 6 months ago #2444
by lkogler
Replied by lkogler on topic SIGSEGV fault for large problems
Yes, you need a new MPI installation. Maybe ask you administrators if they could install it for you.
The MUMPS project does not use cmake. We cannot directly give it the same c/c++/fortran compilers that are used for NGSolve, because it would not find the necessary MPI libraries and flags. Instead, we give it the MPI wrapper-compilers (mpicc, mpicxx, mpifort). When the c/c++/fortran compiler underlying the MPI-wrappers mismatch, you run into problems like yours.
So, when your MPI is compiled with gcc8.3, MUMPS will also be compiled with that version.
Last edit: 5 years 6 months ago by lkogler.
