SIGSEGV fault for large problems
5 years 6 months ago #2436
by gcdiwan
Even with
or
I have no success and I get SIGSEGV faults.
There's no other MUMPS installation on the cluster other than the one that gets downloaded with CMake and the version is 5.2.0.
Thinking about the compatibilities: do you think the following is an issue:
For ngsolve i seem to have (in my ngsolve-src/build/CMakeCache.txt)
whereas, within the Makefile.inc (in build/ngsolve-src/build/dependencies/src/project_mumps/Makefile.inc) for mumps, i have:
Thanks for your help, much appreciated!
Replied by gcdiwan on topic SIGSEGV fault for large problems
If this is sequential, I am guessing i will only be limited with the memory - i will give this a try but this will probably be too slow.(i believe "masterinverse") without telling you (not very pretty, I know), which is why mpi_poisson.py works.
or with how the job is started.
Even with
mpirun -n 8 ngspy mpi_poisson.py
mpirun -n 8 python3 mpi_poisson.py
Are you using the MUMPS built with NGSolve or a separate MUMPS install? We have had issues with MUMPS 5.1 for larger problems. Upgrading to 5.2 resolved those.
If you use a seperate MUMPS install you have to make sure that that MUMPS and NGSolve have been built with the same MPI libraries
CMAKE_CXX_COMPILER:FILEPATH=/opt/gridware/depots/3dc76222/el7/pkg/compilers/gcc/8.3.0/bin/g++
CMAKE_C_COMPILER:FILEPATH=/opt/gridware/depots/3dc76222/el7/pkg/compilers/gcc/8.3.0/bin/gcc
CMAKE_Fortran_COMPILER:FILEPATH=/opt/gridware/depots/3dc76222/el7/pkg/compilers/gcc/8.3.0/bin/gfortran
CC = /opt/gridware/depots/3dc76222/el7/pkg/mpi/openmpi/2.0.2/gcc-4.8.5/bin/mpicc
FC = /opt/gridware/depots/3dc76222/el7/pkg/mpi/openmpi/2.0.2/gcc-4.8.5/bin/mpif90
FL = /opt/gridware/depots/3dc76222/el7/pkg/mpi/openmpi/2.0.2/gcc-4.8.5/bin/mpif90
5 years 6 months ago #2437
by lkogler
Replied by lkogler on topic SIGSEGV fault for large problems
What does "mpicc --version" produce?
If MPI was built with gcc 4.8.5 and NGSolve with gcc 8.3 that might lead to problems.
Ideally you want to use the same compilers.
Do you have access to an MPI version that has been compiled with a compiler version that can also compile NGSolve (e.g gcc 7.3/8.3)?
5 years 6 months ago #2438
by JuliusZ
Replied by JuliusZ on topic SIGSEGV fault for large problems
I can confirm this issue.
I had the same problem and compiling openmpi with gcc 8.3.0 fixed it.
5 years 6 months ago #2439
by lkogler
Maybe we should show a warning when the compiler versions mismatch.
5 years 6 months ago #2440
by JuliusZ
Probably.
But maybe a brief section in the documentation would already be sufficient.
I will share my experience once I got more experience with MPI and also ngs-petsc such that user users can install working versions from the first moment on.
5 years 6 months ago #2441
by gcdiwan
I have:
I am actually confused to see the output of module load for mpi build of ngsolve: so when i load the mpi build for ngsolve via module load, i see:
So I thought I have a 8.3 version available (as an alternative) but I see only 4.8.5 builds:
So most likely I need to have a openmpi built with gcc 8.3?
I have:
mpicc --version
gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-16)
module load apps/ngsolve_mpi/6.2/gcc-8.3.0+python-3.8.0+mpi-2.0.2+atlas-3.10.3+scalapack_atlasshared-2.0.2
libs/gcc/8.3.0
OK
apps/python/3.8.0/gcc-4.8.5
| -- libs/gcc/system ... VARIANT (have alternative: libs/gcc/8.3.0)
OK
libs/atlas/3.10.3/gcc-8.3.0
| -- libs/gcc/8.3.0 ... SKIPPED (already loaded)
OK
OK
libs/scalapack_atlasshared/2.0.2/gcc-8.3.0+openmpi-2.0.2+atlas-3.10.3
| -- mpi/openmpi/2.0.2/gcc-4.8.5 ... SKIPPED (already loaded)
| -- libs/atlas/3.10.3/gcc-8.3.0 ... SKIPPED (already loaded)
OK
apps/ffmpeg/4.1.3/gcc-4.8.5
OK
module load mpi/openmpi/1.
mpi/openmpi/1.10.2/gcc-4.8.5 mpi/openmpi/1.4.5/gcc-4.8.5 mpi/openmpi/1.6.5/gcc-4.8.5 mpi/openmpi/1.8.5/gcc-4.8.5
