How to setup the Neumann Boundary Conditions?
- liubenyuan
5 years 10 months ago #2213
by liubenyuan
How to setup the Neumann Boundary Conditions? was created by liubenyuan
Hi, I want to set up the Neumann boundary conditions. Firstly, I want to recreate the tutorial in
www.math.uzh.ch/compmath/fileadmin/user/...ld_Noam/myManual.pdf
Section 4 3D Elliptic PDEs in NETGEN
But I do not know how to create the Neumann BCs in Python from these codes
Moreover, for the Neumann BCs, I need to set the Zero potential point in the mesh. I found a post about it here:
ngsolve.org/forum/ngspy-forum/672-neumann-boundary#1258
How could I do this? should I force a Dirichlet BCs on a Node ID?
Is there any tutorial in ngspy on the Neumann BCs?
## coefficient for source integral of linear form
define coefficient f
(−4*(x+1)*(z*z+y*y−2)) ,
## coefficient g/beta for Neumann integral of linear form
define coefficient g_beta
0 , (2*(y*y−1)*(z*z−1)) ,
## f i n i t e element space with order=3 and Dirichlet−boundary at −bc=1
define fespace v −order=3 −dirichlet =[1]
## grid function to store solution
define gridfunction u −fespace=v
## linear form
define linearform f −fespace=v
source f
neumann g_beta
- liubenyuan
5 years 10 months ago #2214
by liubenyuan
Replied by liubenyuan on topic How to setup the Neumann Boundary Conditions?
For example, In the following 1D poisson example code, how could I set both the dirichlet and Neumann boundary conditions? For example, f(left) = 10, and f'(right) = -1.
# https://ngsolve.org/forum/ngspy-forum/167-1-d-poisson-with-constant-forcing-function
import ngsolve as ngs
from ngsolve import grad, dx
import netgen.meshing as ng
"""1. generate a 1D mesh"""
m = ng.Mesh()
m.dim = 1
nel = 10
pnums = []
# add nodes and ID
for i in range(nel+1):
node = ng.Pnt(i/nel, 0, 0)
m.Add(ng.MeshPoint(node))
pnums.append(i+1) # node index starts 1
# add elements
for i in range(nel):
m.Add(ng.Element1D([pnums[i], pnums[i+1]], index=1))
# set materials
m.SetMaterial(1, 'material')
# add BC points
m.Add(ng.Element0D(pnums[0], index=1))
m.Add(ng.Element0D(pnums[nel], index=2))
# set boundary condition names
m.SetBCName(0, 'left')
m.SetBCName(1, 'right')
print(pnums)
"""2. compute on this mesh"""
mesh = ngs.Mesh(m)
print(mesh.GetBoundaries())
# Specify Dirichlet boundary conditions
fes = ngs.H1(mesh, order=2, dirichlet='left|right')
# fes = ngs.H1(mesh, order=1, dirichlet=[1, 2])
print("ndof: ", fes.ndof)
print("freedofs: ", fes.FreeDofs())
u = fes.TrialFunction() # symbolic object
v = fes.TestFunction() # symbolic object
# coefficient/stiffness matrix
a = ngs.BilinearForm(fes)
a += grad(u) * grad(v) * dx
print("mat = \n", a.mat)
# Forcing function
f = ngs.LinearForm(fes)
f += 1*v*dx
print("rhs = \n", f.vec)
# boundary conditions
# how to set:
# 1. f(left) = a, dirichlet boundary
# 2. f'(right)*n = b, Neumann boundary
# solution
u = ngs.GridFunction(fes)
u.vec.data = a.mat.Inverse(fes.FreeDofs()) * f.vec
print ("sol = \n", u.vec)
"""3. plot"""
pnts = [i/100 for i in range(101)]
pnts_vals = [(x, u(x)) for x in pnts if mesh.Contains(x)]
fig, ax = plt.subplots()
pnts, vals = zip(*pnts_vals)
ax.plot(pnts, vals, "-b")
# ax.plot(u.vec, "-b")
5 years 10 months ago #2217
Replied by christopher on topic How to setup the Neumann Boundary Conditions?
You need to change the fes line to not have dirichlet on the right side
Then you need to add neumann boundary term to rhs
and for the inhomogeneous dirichlet you need to homogenize the problem as shown here:
ngsolve.org/docu/latest/i-tutorials/unit...chlet/dirichlet.html
fes = ngs.H1(mesh, order=2, dirichlet='left')
# boundary term for neumann
f += neuval*v*ds(definedon="right")
# homogenization of inhomogeneous dirichlet problem
u.Set(dirval, definedon=mesh.Boundaries("left"))
res.data = f.vec - a.mat * u.vec
u.vec.data += a.mat.Inverse(fes.FreeDofs()) * res
The following user(s) said Thank You: liubenyuan
- liubenyuan
5 years 10 months ago - 5 years 10 months ago #2218
by liubenyuan
Dear Christopher, Thank you!
I rewrite the code, and now it can handle both the dirichelt and the neumann BCs! But when I plot the results, it seems like that gfu interpolate the value between [0, 0.1], Is it the right behavior of ngsolve? The problem is now -f''=2, f'(1)=-1, f(0)=1, and the ground truth is -x^2 + x + 1.
For example, in the following code, gfu(0.05) is 0.5474999999999999, which should be a value larger than f(0)
from ngsolve import grad, dx, ds, BND
m = ng.Mesh()
m.dim = 1
nel = 10
pnums = []
# add nodes and ID
# add elements
# set materials
# add BC points
print(pnums)
mesh = ngs.Mesh(m)
# theoretic solution
# source: -f''= 2
# neumann: f'(1) = -1
# dirichlet: f(0) = 1
# f = -x^2 + x + 1
# Source
source_b = 2
f += source_b * v * dx
# 1. f'(right)*n = b, Neumann boundary
neumann_b = -1
f += neumann_b * v * ds(definedon='right')
# form
# solution
gfu = ngs.GridFunction(fes)
dirichlet_b = 1
# gfu.Set(dirichlet_b, BND)
gfu.Set(dirichlet_b, definedon=mesh.Boundaries("left"))
r = f.vec.CreateVector()
r.data = f.vec - a.mat * gfu.vec
# solve
gfu.vec.data = a.mat.Inverse(fes.FreeDofs()) * r
print ("sol = \n", gfu.vec)
"""3. plot"""
pnts_vals = [(x, gfu(x)) for x in pnts if mesh.Contains(x)]
# ax.plot(gfu.vec, "-b")
# fig.savefig('ngsolve-2217.png')
Last edit: 5 years 10 months ago by liubenyuan. Reason: update ground truth in code
5 years 10 months ago - 5 years 10 months ago #2219
You have a += for the inhomogeneous dirichlet problem:
(inhomogeneous solution = homogeneous solution + inhomogeneous bc)
# solve
gfu.vec.data += a.mat.Inverse(fes.FreeDofs()) * r
Last edit: 5 years 10 months ago by christopher.
