- Thank you received: 24
Large Linear Algebra
7 years 7 months ago #391
by hvwahl
Large Linear Algebra was created by hvwahl
I am trying to compute the eigenvalues of an NGSolve matrix originating from a bilinear form B. My attempt has been to follow the documentation and to create an numpy array using B.mat.NumPy() and B.NumPy(). However this gives me the error message
AttributeError: 'ngsolve.la.SparseMatrixd' object has no attribute 'NumPy'
and
AttributeError: 'ngsolve.comp.BilinearForm' object has no attribute 'NumPy'
respectively.
How can I create a numpy array using NGS-Py so that I work with the matrix using numpy?
Best Wishes,
Henry
and
respectively.
Best Wishes,
Henry
7 years 7 months ago #392
by cwinters
Replied by cwinters on topic Large Linear Algebra
Hi Henry,
you should follow this reference .
Getting a scipy matrix and calculating the eigenvalues can be done with the following lines.
If your version of scipy is not new enough (like in my case 0.17.0) you have to cast the output of COO() to a python array.
import scipy.sparse as sp
from scipy.linalg import eig
rows,cols,vals = B.mat.COO()
M = sp.csr_matrix((array(vals),(array(rows),array(cols))))
# M = sp.csr_matrix((vals,(rows,cols)))
lam = eig(M.todense())
The following user(s) said Thank You: hvwahl
7 years 7 months ago #393
by hvwahl
Replied by hvwahl on topic Large Linear Algebra
Hi Christoph,
Thank you for your quick response! Your code runs perfectly
I'm sorry I missed that part of the documentation.
Best wishes,
Henry
Best wishes,
Henry
