Projection of a high order solution on to the lowest order basis.
- BenWilson94
- Junior Member
5 years 9 months ago #2177
by BenWilson94
I have a H(curl) finite element space solution computed for some order (say order=3) and would like to project this solution on to a low order discretisation for the same mesh, but with order =0 elements. I'm guessing this might be through the projector operator
Projector(mask, range) # mask: bit array; range: bool
Is this possible?
Thanks
Ben
Is this possible?
Thanks
Ben
- mneunteufel
- Premium Member
- Thank you received: 59
5 years 9 months ago #2178
by mneunteufel
Replied by mneunteufel on topic Projection of a high order solution on to the lowest order basis.
Hi Ben,
yes, it is possible to use the projection operator. However, it just neglects the information about the high order functions
If you use an HCurl space of order 0 and then use the Set method
also the high order functions will be locally projected yielding to a better approximation, see attached file.
gf_proj = GridFunction(fes_ho)
bt = BitArray(fes_ho.FreeDofs())
bt[:]=True
bt[mesh.nedge:] = False
P = Projector(bt, True)
gf_proj.vec.data = P*gf_ho.vec
fes_ho = HCurl(mesh, order=3)
fes_lo = HCurl(mesh, order=0)
gf_ho = GridFunction(fes_ho)
gf_lo = GridFunction(fes_lo)
#Set something
gf_ho.Set( CoefficientFunction( (x**2*y*(1-y),-y**3*x**2) ) )
#Interpolate high order solution to low order space
gf_lo.Set(gf_ho)
- BenWilson94
- Junior Member
5 years 8 months ago #2181
by BenWilson94
Replied by BenWilson94 on topic Projection of a high order solution on to the lowest order basis.
Hi Michael,
That's excellent, thank you.
Kind regards,
Ben
Kind regards,
Ben
