Help on Elliptic cone primitive and build instructions from source on ubuntu
7 years 8 months ago #381 by Kalez
Hi there,
I'm trying to include a primitive for an elliptic cone in netgen. I have generated appropriate cxx, cyy, czz, cxy, cyz, cx cy, c1 coefficients for the elliptic cone.
I believe one of the files to include this info is algprim.cpp in the source code.
I'm getting ideas from the cone primitive on how to proceed but I'm stuck. Can someone help me please.
I've also been trying to install netgen without modifications from source on a 32 bit machine. However, I'm failing to proceed. The compiler seems to complain on these two lines.
INLINE size_t * TablePrefixSum (FlatArray<unsigned int> entrysize)
and
INLINE size_t * TablePrefixSum (FlatArray<size_t> entrysize)
I'd appreciate a helpful reply.
Below is a detailed error mesage when building:
[ 0%] Building CXX object ngstd/CMakeFiles/ngstd.dir/exception.cpp.o
In file included from /home/myubuntu/Documents/ngsuite/ngsolve-src/ngstd/ngstd.hpp:147:0,
from /home/myubuntu/Documents/ngsuite/ngsolve-src/ngstd/exception.cpp:7:
/home/myubuntu/Documents/ngsuite/ngsolve-src/ngstd/table.hpp: In function ‘size_t* ngstd::TablePrefixSum(ngstd::FlatArray<unsigned int>)’:
/home/myubuntu/Documents/ngsuite/ngsolve-src/ngstd/table.hpp:82:19: error: redefinition of ‘size_t* ngstd::TablePrefixSum(ngstd::FlatArray<unsigned int>)’
/home/myubuntu/Documents/ngsuite/ngsolve-src/ngstd/table.hpp:76:19: note: ‘size_t* ngstd::TablePrefixSum(ngstd::FlatArray<unsigned int>)’ previously defined here
ngstd/CMakeFiles/ngstd.dir/build.make:62: recipe for target 'ngstd/CMakeFiles/ngstd.dir/exception.cpp.o' failed
make[5]: *** [ngstd/CMakeFiles/ngstd.dir/exception.cpp.o] Error 1
CMakeFiles/Makefile2:167: recipe for target 'ngstd/CMakeFiles/ngstd.dir/all' failed
make[4]: *** [ngstd/CMakeFiles/ngstd.dir/all] Error 2
Makefile:138: recipe for target 'all' failed
make[3]: *** [all] Error 2
CMakeFiles/ngsolve.dir/build.make:114: recipe for target 'dependencies/Stamp/ngsolve/ngsolve-build' failed
CMakeFiles/Makefile2:215: recipe for target 'CMakeFiles/ngsolve.dir/all' failed
Makefile:149: recipe for target 'all' failed
make: *** [all] Error 2
myubuntu@myubuntu-OptiPlex-780:~/Documents/ngsuite/ngsolve-build$
7 years 7 months ago #395 by christopher
For installing on 32 bit, try commenting out the line
#define PARALLEL_TABLE
in ngsolve/ngstd/table.hpp
The following user(s) said Thank You: Kalez
7 years 7 months ago #397 by Kalez
Thanks Christopher for your reply.
I realized that despite the error, netgen.exe was actually created when I checked in ngsolve-install/bin
I also managed to include an elliptic cone primitive.
7 years 7 months ago #398 by Kalez
It appears netgen.exe is created when the instructions given at ngsolve.org/docu/latest/install/install_sources.html are followed.
I managed to create an elliptic cone primitive and would like it to be included in netgen for users who may find it useful.
I updated the following files in ngsolve-src/external_dependencies/netgen/libsrc/csg/
algprim.cpp
algprim.hpp
csgeom.cpp
csgparser.cpp
csgparser.hpp
To install, one has to update the existing files in ngsolve-src/external_dependencies/netgen/libsrc/csg/with these and follow the instructions given at ngsolve.org/docu/latest/install/install_sources.html
Please find attached the updated files and example ellipticcone.geo files. These are in a zipped file ellipticcone.tar.gz.
File Attachment:
File Name: ellipticcone.tar.gz
File Size:26 KB
.geo file.
