Using MPI without building from source
5 years 11 months ago #2054
by dfoiles
Using MPI without building from source was created by dfoiles
I have been trying to run NGsolve in parallel on an HPC and I'd like to know if it's possible to use the launchpad download of NGsolve with MPI? I have been trying to compile it from source both on the cluster and in containers, but have run into errors on both that I have been unable to fix.
Thanks
Thanks
5 years 11 months ago #2055
by matthiash
Replied by matthiash on topic Using MPI without building from source
The setup on HPC clusters varies a lot, thus we do not offer prebuilt binaries for such environments.
Often, the default compiler on clusters is too old, which OS/compiler were you using?
For further hints I need your configuration (cmake) command and the complete command line output.
5 years 11 months ago - 5 years 11 months ago #2061
by dfoiles
Replied by dfoiles on topic Using MPI without building from source
The best attempt I've had so far is building NGSolve in a singularity container with an Ubuntu environment. In it, I've installed the packages that are listed on the "Build on Linux" page as well as openmpi-bin, libopenmpi-dev, and numpy/scipy. My cmake command is:
The error message that I've received is quite long and I don't know what parts are relevant, so I'll attach a text file of the whole message. However, I think the important line is:
I've searched for this error message myself and I've seen people suggest adding flags like "-msse4.1", "-march=native", "-march=nehalem", and "-mavx" to CMAKE_CXX_FLAGS. I've tried this and have still gotten the same error.
Thank you for your willingness to help.
cmake -DUSE_MPI=ON -DUSE_GUI=OFF -DCMAKE_INSTALL_PREFIX=${BASEDIR}/ngsolve-install ${BASEDIR}/ngsolve-src
error: inlining failed in call to always_inline '__m256d _mm256_fmadd_pd(__m256d, __m256d, __m256d)': target specific option mismatch
Last edit: 5 years 11 months ago by dfoiles.
5 years 11 months ago #2062
Replied by joachim on topic Using MPI without building from source
edit ngsolve/ngstd.simd.hpp, line 1047
replace #ifdef __AVX2__ by
#ifdef __FMA__
and again in line 1065
#ifdef __FMA__
The following user(s) said Thank You: dfoiles
5 years 11 months ago #2065
by dfoiles
That did the trick. Thank you very much for your help.
5 years 11 months ago #2110
by dfoiles
Sorry to bother you again. Everything in the container is built and I've moved it to the HPC. I can successfully run the MPI tutorials provided in the source, but when I try to run my program, I get segmentation faults. Specifically, I get:
I have attached a copy of the code that I used.
Thank you for your help.
[node4][[23534,1],3][btl_tcp_frag.c:237:mca_btl_tcp_frag_recv] mca_btl_tcp_frag_recv: readv failed: Connection reset by peer (104)
[node4][[23534,1],4][btl_tcp_frag.c:237:mca_btl_tcp_frag_recv] mca_btl_tcp_frag_recv: readv failed: Connection reset by peer (104)
Caught SIGSEGV: segmentation fault
Collecting backtrace...
#1 /opt/ngsuite/ngsolve-install/lib/python3/dist-packages/netgen/../../../libngcore.so(+0x1864b) [0x7fa70f33664b]
#2 /lib/x86_64-linux-gnu/libc.so.6(+0x43f60) [0x7fa7109bef60]
