Element weighting
5 years 11 months ago #2005 by NilsHM
Element weighting was created by NilsHM
Hello everyone!
I'm working on a hyper-reduction method where each element in the mesh has a unique weight.
The weights must be applied to the local element stiffness matrices during the assembly to the bilinear form.
Is there a way of doing that given a vector of element weights?
Or else is there a way to get single element stiffness matrices in global coordinates?
Thank you
Nils
5 years 11 months ago - 5 years 11 months ago #2006 by christopher
Replied by christopher on topic Element weighting
You can do this quite easily with a c++ extension. Basically you need to follow the first two steps of the c++ tutorial here: ngsolve.org/docu/latest/mylittlengs/1_Basic/README.html
You can for example parse the elementwise coefficients as a list or a numpy array and store them in a c++ array. Then in the evaluate function of your coefficient you query the element number by
int elnr = mip.GetTransformation().GetElementNr();
Then return the corresponding value from the array.
You can then use this CoefficientFunction in your stiffness bilinearform.
I hope this helps, if you run into problems write again. This part of the documentation is not often used yet.
Last edit: 5 years 11 months ago by christopher.
5 years 11 months ago #2057 by NilsHM
Replied by NilsHM on topic Element weighting
Hello Christopher,
thank you for the help.
I got as far as making a CoefficientFunction that gives the element number.
But I need the CoefficientFunction to know the element weights. You said to store the weights in an array. At what point can I do that?
I tried to initialize with the array.
The idea was to initialize my custom CoefficientFunction like this:
cf = ElementWeightCF(weights)
But that didn't work:
TypeError: __init__(): incompatible constructor arguments. The following argument types are supported: 1. CppExtension.cppextension.ElementWeightCF()
It seems like the issue is to initialize the ngsolve CoefficientFunction with to many arguments.
You can find my .hpp file in the attachments.
How can I fix that issue or is there a better way of passing the element weights to my c++ CoefficientFunction?
Thanks in advance
Nils
File Attachment:
File Name: ElementWeightCF.hpp
File Size:1 KB
5 years 11 months ago #2058 by christopher
Hi Nils,
the code in your hpp seems ok, I expect the problem is in the binding code. Can you send the cpp file as well?
5 years 11 months ago - 5 years 11 months ago #2059 by NilsHM
You can find the remaining code in the attachments.
File Attachment:
File Name: ElementWeightCF.cpp
File Size:1 KB
File Attachment:
File Name: cppextension.cpp
File Size:1 KB
Last edit: 5 years 11 months ago by NilsHM.
5 years 11 months ago #2060 by christopher
The export of the constructor is wrong, the template arguments for the py::init must be the arguments for the constructor:
.def(py::init<py::array_t<double>>())
best
