"Didn't find pointer" message whist using multiprocessing
- BenWilson94
- Junior Member
5 years 10 months ago #1937
by BenWilson94
I am having an issue whilst using NGSolve version 6.2.1908 in parallel on a Linux machine. The same code works on a Linux machine running NGSolve version 6.2.1905-45-g73eb677a and works for mac using 6.2.1905.
part of the message received was
Loading a nullptr
Typeids are different: ngfem::CoefficientFunction vs ngfem::ConstantCoefficientFunction
Reading pointer of type std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >
Didn't find pointer, create new registry entry at 0Loading a nullptr
Store a possibly more complicated pointer
Writeout version needed = Loading a nullptr
Reading pointer of type std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >Pickling output for object of type ngfem::CoefficientFunction = ([b'\xfd\xff\xff\xff"\x00\x00\x00ngfem::ConstantCoefficientFunction\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xf0?', b'\x00\x00\x00\x00\x00\x00\x00\x00', b'\x00\x00\x00\x00\x00\x00\x00\x00'],)
As far as I can tell the results obtained are still the same but there is a significant decrease in performance.
Kind regards,
Ben
Loading a nullptr
Kind regards,
Ben
5 years 10 months ago - 5 years 10 months ago #1938
Replied by christopher on topic "Didn't find pointer" message whist using multiprocessing
Yes we added a lot more debug output while pickling... This is way too much for normal program run. As a workaround you can set the ngsglobals.msg_level down, we will reduce the default logging output from debug to info in future releases.
Thanks for reporting,
Last edit: 5 years 10 months ago by christopher.
- BenWilson94
- Junior Member
5 years 10 months ago #1939
by BenWilson94
Replied by BenWilson94 on topic "Didn't find pointer" message whist using multiprocessing
Hi Christopher,
That's excellent, thank you for your help.
Kind regards,
Ben
Kind regards,
Ben
