- Thank you received: 6
Safty check for matrix inversion
- Guosheng Fu
- Elite Member
5 years 11 months ago #1925
by Guosheng Fu
Safty check for matrix inversion was created by Guosheng Fu
When umfpack direct solver fails to factorize the linear system (due to singularity), the code simply crashes.
Is there a safer way to proceed other than producing the following error message and exit the code?
I noticed pardiso solver will still proceed with the factorization, but producing nan values.
Guosheng
netgen.libngpy._meshing.NgException: UmfpackInverse: Numeric factorization failed.
Guosheng
- mneunteufel
- Premium Member
- Thank you received: 59
5 years 11 months ago #1927
by mneunteufel
Replied by mneunteufel on topic Safty check for matrix inversion
Hi Guosheng,
you can use the try - except syntax of Python
Then the code does not exit.
try:
a.mat.Inverse(fes.FreeDofs(), inverse="umfpack")
except:
print("Singular matrix")
