Interfacing 3D surface mesh data with Numpy
6 years 3 weeks ago #1898 by MA
I'm a new user. So, sorry if my question is too basic.
I have this simple example
import netgen.csg as csg
geo = csg.CSGeometry()
sphere = csg.Sphere(csg.Pnt(0, 0, 0), 3)
geo.Add(sphere)
mesh = geo.GenerateMesh(maxh=1.5)
and I need to store in numpy arrays the information that I am able to store in an STL file without having to export and import again in STL format. Information consists of the coordinates of the 3 points of triangles and the normal vector.
Thank you for your help.
MA
6 years 3 weeks ago #1899 by hvwahl
Hi MA,
if it is specifically only a numpy array you need to store and reload, numpy has a save function . For more general objects (including ngsolve objects, such as GridFunctions, FESpaces...), you could use pythons pickle module:
import numpy as np import pickle x = np.array([1,2,3]) y = np.array([4,5,6]) pickle.dump([x,y], open("filename", "wb")) unpickler = pickle.Unpickler( open("filename", "rb") ) a,b = unpickler.load() for i in range(len(x)): assert a[i] == x[i] for i in range(len(y)): assert b[i] == y[i]
Best wishes,
Henry
6 years 3 weeks ago - 6 years 3 weeks ago #1902 by MA
Thank you Henry.
However, I want to avoid exporting my mesh into an STL file then read it again to get it stored into a numpy array.
Is there another way to get, for a 3D surface mesh, the coordinates of the 3 points of each elementary triangle (facet) and the local normal vector?
Thanks a lot for your time.
Regards,
MA
Last edit: 6 years 3 weeks ago by MA.
6 years 3 weeks ago #1904 by hvwahl
Hi MA,
sorry, I misunderstood your original question. You can access the coordinates of all triangle vertices
for el in mesh.Elements2D(): for i in range(3): print(mesh.Points()[el.vertices[i]])
but I guess this is not exactly what you are looking for.
Best wishes,
Henry
6 years 3 weeks ago #1906 by MA
Thanks Henry,
This helps. Any idea how to find the normal vectors?
Thanks
6 years 3 weeks ago #1909 by hvwahl
not from within netgen. You could always compute a normal as
[tex]\bf n = \frac{ e_1\times e_2}{\Vert e_1\times e_2 \Vert} [/tex]
[tex]\bf e_i = v_i - v_3 [/tex]
for i = 1,2 are two of the triangle edges. But these might not be outward pointing.
Best wishes,
Henry
Time to create page: 0.178 seconds
