Precommands needed for getting better pictures/
5 years 11 months ago #1859
by mischl
Precommands needed for getting better pictures/ was created by mischl
Hey, google didn't help me
I wanted to ask the following questions to improve my pictures
a) what command hides the grid-triangles automatically? When creating a look with multiple runs it's exhausting to do it by hand
b) Are there any options for the horizontal bar on top?
like being vertical, having less but larger numbers (it's pretty small with height of 5cm in a file)
c) I sometimes have that lag in exporting pictures, because the program is faster then creating+exporting the picture, I was told I should do a break before exporting it. Is there any explanation/link around how to best do it?
Thanks alot in advance and as always: great project!
5 years 11 months ago #1860
by hvwahl
Replied by hvwahl on topic Precommands needed for getting better pictures/
personally, I would do a VTK output ( NGSolve Examples ) and then do everything in paraview.
Best wishes,
Henry
Best wishes,
Henry
The following user(s) said Thank You: mischl
5 years 11 months ago #1861
by matthiash
Replied by matthiash on topic Precommands needed for getting better pictures/
There visual options are exposed in the ngsolve.internal module. Most options can be changed by members of 'viewoptions' and 'visoptions', which provide write-only access to the according Tcl-Variables in the GUI.
The color bar cannot be changed directly in appearance. Concerning the pictures: Are you using the SnapShot function like above? It should automatically block further execution until the image is exported.
import ngsolve.internal as ngsint
ngsint.viewoptions.drawoutline=0 # triangle outline
ngsint.SnapShot('image.bmp')
5 years 11 months ago #1900
by mischl
Replied by mischl on topic Precommands needed for getting better pictures/
Hey, will look into that when I find the time, thanks!
5 years 11 months ago #1901
by mischl
Thanks, is there an overview somewhere hidden for all the possibilities?
And yes, I use ngsolve.internal.SnapShot(...) and no, it doesn't block for me and neither for a colleague, very often, the first picture is repeated in the Exports
5 years 11 months ago #1915
by matthiash
You can check the members of the variables viewoptions and visoptions in ngsolve.internal:
Note that, due to asynchronous evaluation, there is only write and no read access to these values.
importing NGSolve-6.2.1908-6-gf77e4e6b
>>> dir(ngsolve.internal.viewoptions)
['_attributes', '_name', '_update_cmd', 'centerpoint', 'centerx', 'centery', 'centerz', 'clipping', 'colormeshsize', 'drawbadels', 'drawcolorbar', 'drawcoordinatecross', 'drawcurveproj', 'drawcurveprojedge', 'drawdomainsurf', 'drawededgenrs', 'drawededges', 'drawedgenumbers', 'drawedges', 'drawedpointnrs', 'drawedpoints', 'drawedtangents', 'drawelement', 'drawelementnumbers', 'drawfacenumbers', 'drawfilledtrigs', 'drawhexes', 'drawidentified', 'drawmetispartition', 'drawnetgenlogo', 'drawoutline', 'drawpointnumbers', 'drawprisms', 'drawpyramids', 'drawspecpoint', 'drawtets', 'drawtetsdomain', 'light', 'mat', 'shrink', 'specpointvlen', 'specpointx', 'specpointy', 'specpointz', 'stereo', 'usecentercoords', 'whitebackground']
>>> dir(ngsolve.internal.visoptions)
['_attributes', '_name', '_update_cmd', 'autoredraw', 'autoredrawtime', 'autoscale', 'clipsolution', 'deformation', 'drawfieldlines', 'drawpointcurves', 'evaluate', 'evaluatefiledescriptions', 'evaluatefilenames', 'fieldlinesfilename', 'fieldlineslength', 'fieldlinesmaxpoints', 'fieldlinesonlyonephase', 'fieldlinesphase', 'fieldlinesrandomstart', 'fieldlinesrktype', 'fieldlinesstartarea', 'fieldlinesstartareap1x', 'fieldlinesstartareap1y', 'fieldlinesstartareap1z', 'fieldlinesstartareap2x', 'fieldlinesstartareap2y', 'fieldlinesstartareap2z', 'fieldlinesstartface', 'fieldlinesthickness', 'fieldlinestolerance', 'fieldlinesvecfunction', 'gridsize', 'imaginary', 'invcolor', 'isolines', 'isosurf', 'lineartexture', 'lineplotautoscale', 'lineplotcolor', 'lineplotcurrentnum', 'lineplotdatadescr', 'lineplotfile', 'lineplotinfos', 'lineplotselected', 'lineplotselectedeval', 'lineplotselector', 'lineplotsizex', 'lineplotsizey', 'lineplotsource', 'lineplotusingx', 'lineplotusingy', 'lineplotxcoordselector', 'lineplotxmax', 'lineplotxmin', 'lineplotycoordselector', 'lineplotymax', 'lineplotymin', 'logscale', 'mmaxval', 'mminval', 'multidimcomponent', 'numfieldlines', 'numiso', 'numtexturecols', 'redrawperiodic', 'scaledeform1', 'scaledeform2', 'scalfunction', 'showclipsolution', 'showsurfacesolution', 'simulationtime', 'subdivisions', 'usetexture', 'vecfunction', 'xoffset', 'yoffset']
