Adaptive Mesh Refinement in 3D
6 years 1 week ago #1940 by Elsakori
Hello Christopher,
Thank you for your assistance.
Do I need to Install the latest release or the nightly build release to get these changes?.
Regards,
Ahmed
6 years 1 week ago #1943 by christopher
currently it is only in the nightly release, but we plan to release 1909 this weak.
6 years 1 week ago #1948 by Elsakori
Hello Christopher,
The latest nightly build doesn't work on my macOS (10.12.6). Actually any release from September 3 and older works fine, but the latest ones (September 4 and later) do not work.
Ahmed
6 years 1 week ago #1949 by tommaso
I was trying to do something very similar here. I would like to solve an electrostatic problem in 3D and use the adaptive refinement method to improve the result accuracy.
In practice I want to do the following.
I build a 3D geometry composed of a prism which contains come charge density surrounded by a "vacuum" domain enclosed in a far external surface (a sphere).
I than try to solve the BVP of the related Poisson problem with the adaptive refinement algorithm as in the example in section 1.6 (Error estimation & adaptive refinement).
I also added the lines of code suggested by Christopher to remove the refinement flags for surface elements.
As a result, i find a strange behavior of the error estimator. Indeed, with increasing mesh density the
error estimate tends to zero, but not with a monotonic manner (as in the tutorial example).
I have the feeling there is something wrong going on, but I can't say if it's a problem of my code or something related to the 3D refinement as faced by Ahmed.
I'm attaching the code.
Thanks in advance for the help.
Tommaso
6 years 1 week ago #1950 by joachim
Hi Tomasso,
have a look at your solution ... and think about your boundary conditions
J
6 years 1 week ago #1951 by tommaso
Hi Joachim,
My bad. It was a stupid mistake. Thanks for pointing that out.
Tommaso
