- Thank you received: 24
Linux building issue
6 years 1 month ago #1713
by hvwahl
Replied by hvwahl on topic Linux building issue
Hi Presley,
it looks to me like you are using gcc 5. NGSolve needs a compiler with c++17 support, so gcc7.3 or clang 7 or higher (see ngsolve.org/forum/ngspy-forum/747-build-...lem-new-version#1478 ).
Best wishes,
Henry
Best wishes,
Henry
6 years 1 month ago #1718
by Presley
Replied by Presley on topic Linux building issue
Hi Henry! Thanks a lot! After I updated the gcc to 7 it worked through the making and installing step. But when I tried to run an example it failed...
What did I do wrong? May I also ask how to turn the cmake options ON? I need PARDISO to run a code but by default it's turned off.
Thanks in advance!
Regards,
Rob
➜ intro netgen navierstokes.py
NETGEN-6.2-dev
togl-version : 2
loading ngsolve library
NGSolve-6.2.1905-166-g03a9230
Using Lapack
Running parallel using 8 thread(s)
File "<string>", line 1, in <module>
ImportError: No module named 'ngsolve'
(should) load python file 'navierstokes.py'
Finished executing navierstokes.py
ImportError: No module named 'netgen'
Thank you for using NGSolve
Thanks in advance!
Regards,
Rob
6 years 1 month ago #1719
by hvwahl
Hi Rob,
with respect to PARDISO: As far as I'm aware, the best way is to have PARDISO available is to build NGSolve with Intel MKL software.intel.com/en-us/mkl . You then need to add the following cmake flags when building NGSolve
c.f.
ngsolve.org/forum/ngspy-forum/670-build-with-pardiso
Your error looks to me like ngsolve is not in your PYTHONPATH path variable. Maybe check if all you path/pythonpath variables are set correctly: You should have a directory similar to
(depending on you python3 version and where you installed NGSolve) which contains a folder "ngsolve" within which there are then a load of python files. Make sure that the "site_packages" directory is in you pythonpath.
Best wishes,
Henry
-DMKL_ROOT=${MKLROOT} -DUSE_MKL=ON
NGSolve/inst/lib64/python3.6/site-packages
Best wishes,
Henry
6 years 1 month ago #1720
by Presley
Hi Henry,
Thanks a lot! It worked after I set up the PYTHONPATH variable properly!
Regarding to PARDISO, I downloaded it from what you pointed me to and installed it. Here is the error msg from cmake:
It seems adding that flag is not enough and there is need to set up some other environment variables for Cmake to find MKL?
Rob
➜ ngsolve-build cmake -DCMAKE_INSTALL_PREFIX=${BASEDIR}/ngsolve-install -DMKL_ROOT=${MKLROOT} -DUSE_MKL=ON ${BASEDIR}/ngsolve-src
-- Build Netgen from git submodule
Configure Netgen from submodule...
Checking for write permissions in install directory...
-- Found Pybind11: /home/user/ngsuite/ngsolve-src/external_dependencies/netgen/external_dependencies/pybind11/include
-- Configuring done
-- Generating done
-- Build files have been written to: /home/user/ngsuite/ngsolve-build/netgen
CMake Warning (dev) at cmake/SuperBuild.cmake:129 (find_package):
Policy CMP0074 is not set: find_package uses <PackageName>_ROOT variables.
Run "cmake --help-policy CMP0074" for policy details. Use the cmake_policy
command to set the policy and suppress this warning.
CMake variable MKL_ROOT is set to:
/home/user/intel
For compatibility, CMake is ignoring the variable.
Call Stack (most recent call first):
CMakeLists.txt:61 (include)
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Error at /usr/local/share/cmake-3.15/Modules/FindPackageHandleStandardArgs.cmake:137 (message):
Could NOT find MKL (missing: MKL_INCLUDE_DIR MKL_LIBRARY
MKL_MINIMAL_LIBRARY)
/usr/local/share/cmake-3.15/Modules/FindPackageHandleStandardArgs.cmake:378 (_FPHSA_FAILURE_MESSAGE)
cmake/cmake_modules/FindMKL.cmake:151 (find_package_handle_standard_args)
-- Configuring incomplete, errors occurred!
See also "/home/user/ngsuite/ngsolve-build/CMakeFiles/CMakeOutput.log".
See also "/home/user/ngsuite/ngsolve-build/CMakeFiles/CMakeError.log".
Rob
6 years 1 month ago #1721
Replied by christopher on topic Linux building issue
Hi Rob,
Usually the mkl root is intel/mkl and not intel. Can you check setting mkl root to /home/user/intel/mkl?
