DG and Newtons method linearization
7 years 9 months ago #330 by cwinters
Hi Bart,
HDG was not fully implemented for 1D. An updated version as available on Github and you can pull it from there. If you use an installer, you can update/download ngsolve_nightly tomorrow.
If you want to use HDG, you have to use an discontinuous finite element space for your element variable (e.g. L2). For a 1d mesh, you just have one degree of freedom on the facets, thus you have a 0th order facet finite element space.
order = 4 V1 = L2(mesh, order=order) V2 = FacetFESpace(mesh, order=0, dirichlet=[1]) V = FESpace([V1,V2])
A full example solving a laplace problem with HDG is attached.
The following user(s) said Thank You: Matejczyk
7 years 8 months ago - 7 years 8 months ago #337 by Matejczyk
Thanks for the previous answer. I defined my spaces as you advised and now they look like
Y = L2(mesh, order=ord) # space can be fixed for the whole routine Z = FacetFESpace(mesh, order=0,dirichlet = [1,2]) X = FESpace([Y,Z,Y,Z,Y,Z])
As always there is a but. Now I struggle with the definitions of the BC and the initial guess for the Newton loop.
What I have is
u.components[1].vec[nel] = Vapl u.components[3].vec[nel]=z1*beta*Vapl + log(bc1) u.components[5].vec[nel]=z2*beta*Vapl + log(bc1)
which (as I believe) provides the right boundary conditions for the facet space and should provide the BC for the Newton loop. Unfortunately this way the code gets stuck on the line
a.Apply(u.vec, res)
I fixed this issue and it is not stuck any more. I needed to increse the heapsize by seting
a.Apply(u.vec, res, heapsize=100000000)
Now I end up with a singular matrix so I believe the BC/initialization problem stays the same.
Is there a better way to implement the BC and the initial guess than the one I'm using?
Best wishes,
Bart
Last edit: 7 years 8 months ago by Matejczyk.
7 years 8 months ago #338 by cwinters
for the 1d case, your way of setting the boundary conditions should work. (The Set() function which you used before does not support points by now.)
Which matrix is singular? The result of "a.Apply(...)" is a vector.
If you do not set anything else than those three boundary values, all other values in "u.vec" are 0. Is that the vector you want to start with?
7 years 8 months ago #339 by Matejczyk
I thought that I'm doing something wrong with the Set function. Is good to know that it is not only me.
For the BC and the initial Guess.
I set 3 boundary conditions manually by
u.components[1].vec[nel]=
so that the facet space vector is 0 everywhere but the boundary. I don't set anything for the values of the functions in the L2 space.
Then my system enters the Newtons loop and what I get is
linear form done
Iteration 0
<A u 0 , A u 0 >_{-1}^0.5 = 190.3901437327294
Iteration 1
<A u 1 , A u 1 >_{-1}^0.5 = 2.0534197662160665
UMFPACK V5.7.4 (Feb 1, 2016): WARNING: matrix is singular
so I get a singular matrix in my Newton loop which looks like
res = u.vec.CreateVector() du = u.vec.CreateVector() SetHeapSize(100000000) ################################# newton loop for it in range(250): a.Apply(u.vec, res) a.AssembleLinearization(u.vec) du.data = a.mat.Inverse(X.FreeDofs()) * res u.vec.data -= du #stopping criteria stopcritval = sqrt(abs(InnerProduct(du,res))) print ("Iteration",it) print ("<A u",it,", A u",it,">_{-1}^0.5 = ", stopcritval)
. The problematic line is the inverse now. Any ideas why the HDG formulation might lead to a singular matrix? I was solving the same system just in H1 space and I didn't have this problem.
Best wishes,
B
7 years 8 months ago #340 by cwinters
could you please attach your updated file with the HDG formulation.
7 years 8 months ago #341 by Matejczyk
The problem with the singular matrices arises because in my bilinear form I have some functions that are x dependent A(x) and Sigma(x) (you can see the code attached). Before I was just assigning values to the vectors manually using Sigma.vec = g(i) . As now Sigma is a GridFunction(L2) this way is a no longer valid method of assigning values. I changed it then and in the code, I attach I just set
Sigma.Set(x)
to have something. Now the Newton loop converges but my ability to assign values is somehow limited. We are somehow back to the Set function we discussed before. Is there any way to assign the values of this functions (A and sigma) such that I can use for example indicator functions over x?
Best wishes,
Bart
