vector XFESpace for xfem inclusion problem in elasticity
- camilo.suarezafanador
6 years 3 months ago #1698
by camilo.suarezafanador
Dear Colleagues I'm writing a ngs-py file to deal with the inclusion problem and I've a problem with the dimension space when trying:
Clearly the problem is because Vh is dim = 2 and Vhx is dim = 1.
My question then is :
Which flag I've to apply to XFESpace function to deal with the dimension of Vh
Vh = H1(mesh, order=1, dirichlet="left|right", dim=mesh.dim)
Vhx = XFESpace(Vh, ci)
VhG = FESpace([Vh,Vhx])
NgException: Compound space of spaces with different dimensions is not allowed
6 years 3 months ago #1699
by schruste
Replied by schruste on topic vector XFESpace for xfem inclusion problem in elasticity
Sorry, I think this not fixable with a flag, yet. I will have to program this into the XFESpace. However, this will take some time for me to find the time for it...
Perhaps you can find a CutFEM-characterization for the same problem? With Compress(..) you can reduce the dofs to the same amount. Alternatively you could replace the vector-valued FESpace by multiple scalar FESpaces.
6 years 2 months ago #1714
Replied by camilo.suarezafanador on topic vector XFESpace for xfem inclusion problem in elasticity
Thank you so much for the answer Mr Schruste, it would be so nice if you coul say me where can I find the CutFEM application, and my question about the multiple Scalar FESpace is how I could implemented this definition for example applying the Grad or Div, have I to define each one or I can Apply the operator directly
Thank you so much for your answer,
Best Regards
Camilo
Best Regards
Camilo
5 years 6 months ago #2539
by nepomuk
Replied by nepomuk on topic vector XFESpace for xfem inclusion problem in elasticity
I think I have quite a similar problem, I'd like to do XFEM for linear elasticity, I defined the FE spaces like
Now it hangs up when doing the neg() or pos() function like
saying
Is there a way to fix it, apart of using two FE spaces coordinatewise?
BR,
Nepomuk
Vh = VectorH1(mesh, order=1)
Vhx = XFESpace(Vh,ci)
u_std, u_x = VhG.TrialFunction()
u = [u_std + neg(u_x)]
saying
NgException: Dimensions don't match, op = + dims1 = 0: 2, dims2 = 0: 1
BR,
Nepomuk
5 years 6 months ago #2541
by schruste
Oh, I completely forgot about this issue! Thanks for the reminder.
I fixed the XFESpace so that it is now able to deal with base FESpaces that have a higher dimension. The changes are in the master branch on github, but not yet in the release branch which is the standard branch on github (to come within a few weeks). So please checkout the latest "master" branch on github and recompile ngsxfem.
Afterwards, use H1(mesh, dim=mesh.dim) instead of VectorH1 (VectorH1 is still not supported by XFESpace). With dim=mesh.dim however elasticity should be possible now. Please give it a try! I'd be nice if you could report if things are working for you.
The following user(s) said Thank You: camilo.suarezafanador
5 years 6 months ago #2547
by nepomuk
Hi Christoph,
The XFE Space workes fine, but I got another issue: I do need the transposed gradient, but
gives the error AttributeError: 'list' object has no attribute 'trans'...
How can I do this?
BR, Nepomuk
gradu.trans
gradu = [grad(u_std) + op(u_x) for op in [neg_grad,pos_grad]]
How can I do this?
BR, Nepomuk
Time to create page: 0.191 seconds
