Accessing connectivity for a mesh object
- bhaveshshrimali
- Junior Member
6 years 2 months ago #1667
by bhaveshshrimali
Accessing connectivity for a mesh object was created by bhaveshshrimali
I am experimenting with the python interface and trying to obtain a second order mesh. Consider the following MWE:
This outputs only `3` vertices, and if I am correct, the first three. How to access the complete connectivity for each element ? What is a better approach to generate a 6-noded triangular mesh.
# Some code to generate a `geo` object
mesh = geo.GenerateMesh(maxh=10)
mesh.SecondOrder()
Elems = mesh.Elements2D()
for elem in Elems:
print(elem.vertices)
- mneunteufel
- Premium Member
- Thank you received: 59
6 years 2 months ago #1668
by mneunteufel
Replied by mneunteufel on topic Accessing connectivity for a mesh object
Hi bhaveshshrimali,
you get always only the three vertex points of the triangle. Use
instead to get all 6. The first three will coincide with the result from elem.vertices.
elem.vertices
elem.points
The following user(s) said Thank You: bhaveshshrimali
- bhaveshshrimali
- Junior Member
6 years 2 months ago #1670
by bhaveshshrimali
Replied by bhaveshshrimali on topic Accessing connectivity for a mesh object
Ah I see, Thanks. Makes complete sense. What I meant was the points on the triangle (and not just the vertices).
Thank you very much!!
Bhavesh
Bhavesh
