- Thank you received: 24
Mac build problem
6 years 2 months ago - 6 years 2 months ago #1665
by hvwahl
Mac build problem was created by hvwahl
I just tried to install NGSolve from the sources on my Mac (MacOS 14.5) in the same manner I have always done. Unfortunately this failed:
I have attached the full terminal Output.
The motivation behind a clean install, was because the Netgen GUI crashed on startup, see . (The python interface was working.)
Can anyone help with these issues?
Best wishes,
Henry
[ 29%] Building CXX object fem/CMakeFiles/ngfem.dir/hcurlfe.cpp.o
/Applications/NGSolve/src-ngs/fem/hcurlfe.cpp:463:7: error: use of undeclared identifier 'testout'
(*testout) << "a = " << a << endl;
/Applications/NGSolve/src-ngs/fem/hcurlfe.cpp:481:8: error: use of undeclared identifier 'testout'
(*testout) << "breakdown in householder, a = " << a << endl;
/Applications/NGSolve/src-ngs/fem/hcurlfe.cpp:650:7: error: use of undeclared identifier 'testout'
(*testout) << " Compute Gradient Matrix H1-HCurl Low order FEs " << endl
/Applications/NGSolve/src-ngs/fem/hcurlfe.cpp:2684:7: error: use of undeclared identifier 'testout'
(*testout) << "fiphij3 = " << endl << fiphij3 << endl;
4 errors generated.
make[5]: *** [fem/CMakeFiles/ngfem.dir/hcurlfe.cpp.o] Error 1
make[5]: *** Waiting for unfinished jobs....
make[4]: *** [fem/CMakeFiles/ngfem.dir/all] Error 2
make[3]: *** [all] Error 2
make: *** [all] Error 2
Best wishes,
Henry
Last edit: 6 years 2 months ago by hvwahl.
6 years 2 months ago #1673
by matthiash
Replied by matthiash on topic Mac build problem
Hi Henry,
testout was moved to Netgen, so I guess you didn't update the submodule before building NGSolve:
The second issue is nagging us since the last MacOS update. In order to get Netgen running, you need to download an old SDK (Version 10.9 from here: github.com/phracker/MacOSX-SDKs ) and point CMake to it at configure time:
# in source dir of NGSolve:
git submodule update --init --recursive
export MACOSX_DEPLOYMENT_TARGET=10.9
cmake -DCMAKE_OSX_SYSROOT=path_to_your_sdk ...
6 years 2 months ago #1675
by hvwahl
Replied by hvwahl on topic Mac build problem
Hello Matthias,
thank you for your response! I looked into the terminal output and I did update the submodules. I also tried to build it with the latest sources and the SDK 10.9 but had the same issue with testout.
Best wishes,
Henry
Best wishes,
Henry
6 years 2 months ago #1676
by matthiash
Now I see the issue: You have another installation of Netgen/NGSolve in /Applications/Netgen.app
The build erroneously uses this incompatible Netgen version to build NGSolve.
I will see that this gets fixed, in the meantime you have to (re)move the other version at /Applications/Netgen.app before building you own one.
6 years 2 months ago #1677
by hvwahl
Thank you Matthias! This has worked now!
It hadn't occurred to me that the Netgen.app would be a problem, as I did not add it to my Path variable.
Best wishes,
Henry
Best wishes,
Henry
