- Thank you received: 6
MPI related question: how to evaluate a coefficient function
- Guosheng Fu
- Elite Member
6 years 4 months ago #1543
by Guosheng Fu
I am trying to evaluate a grid function at a specific mesh point, but it failed for the MPI version with the following snippet...
if mesh.Contains(0,0):
gfu(mesh(0,0))
6 years 4 months ago - 6 years 4 months ago #1548
by lkogler
Replied by lkogler on topic MPI related question: how to evaluate a coefficient function
It looks like empty meshes (rank 0 has no elements) are not handled correctly.
As a workaround:
Should be fixed shortly.
As a workaround:
if mesh.comm.rank!=0 and mesh.Contains(0,0):
gfu(mesh(0,0))
Last edit: 6 years 4 months ago by lkogler.
- Guosheng Fu
- Elite Member
6 years 4 months ago #1549
by Guosheng Fu
Replied by Guosheng Fu on topic MPI related question: how to evaluate a coefficient function
Thanks!
Say, do you have any suggestions on code debugging in MPI?
It would be a good exercise for me to trace a bug and try to fix it myself first before asking these small questions...
6 years 4 months ago - 6 years 4 months ago #1553
by lkogler
I have not found a solution I am really satisfied with myself, but I can tell you what I usually do.
Just keep in mind that this is all just cobbled together.
For small jobs, you can run each MPI process in a seperate xterm-window and attach gdb to each of them.
You can also pipe the output of each process to a seperate file, for example, with OpenMPI you could write
a small script like this:
Then you can use gdb on each process, and tell it to print the back-trace when it encounters a problem
This way you can do bigger jobs, but you cannot use gdb interactively.
This also works with valgrind instead of gdb.
mpirun -np 1 gdb -ex run --args python3 PYTHON_SCRIPT : \
-np X xterm -hold -e gdb -ex run --args python3 PYTHON_SCRIPT
#!/bin/sh
$@ 1>out_p$OMPI_COMM_WORLD_RANK 2>err_p$OMPI_COMM_WORLD_RANK
mpirun -np X bash WRAP_SCRIPT gdb -batch -ex "run" -ex bt --args python3 PYTHON_SCRIPT
