vtk and Revolution()
6 years 8 months ago #1497 by pschroe
vtk and Revolution() was created by pschroe
Hey guys,
I have a problem when I want to write a vtk with a 3D geometry which results from the revolution of a 2D spline.
For example, I took the torus example from "Netgen Examples" and added a vtk output in the attached script.
The resulting .vtk file then cannot be read by ParaView (it gives a strange error message).
Am I doing something wrong here?
Best, Philipp
6 years 7 months ago #1501 by schruste
Replied by schruste on topic vtk and Revolution()
Dear Philipp,
I cannot reprocude a problem with your file. Can you send your vtk-file to exclude that this is a paraview (version?) issue?
Also: Can you attach the "strange error messages"?
6 years 7 months ago - 6 years 7 months ago #1502 by pschroe
Replied by pschroe on topic vtk and Revolution()
Dear Christoph,
I get the following error for both ParaView versions 5.5 and 5.6:
Generic Warning: In /Users/kitware/dashboards/buildbot-slave/8275bd07/build/superbuild/paraview/src/VTK/IO/Legacy/vtkDataReader.cxx, line 1436 Error reading ascii data. Possible mismatch of datasize with declaration. ERROR: In /Users/kitware/dashboards/buildbot-slave/8275bd07/build/superbuild/paraview/src/VTK/IO/Legacy/vtkUnstructuredGridReader.cxx, line 346 vtkUnstructuredGridReader (0x7fe194a11310): Unrecognized keyword: -0.899858
Attached you'll find the vtk file (remove the .py etc. in the filename which I added to fool the restricted file extensions).
The NGSolve version which produced the file is 8ccd382e (09.02.19).
Best, Philipp
Last edit: 6 years 7 months ago by pschroe.
6 years 7 months ago #1503 by schruste
Your file works on my machine. So, I am still not sure if it's a problem with the export or with paraview. My paraview version is 5.6.0.
6 years 7 months ago - 6 years 7 months ago #1504 by pschroe
Well, this is odd ;)
My problem occurs on a Mac machine, however.
I just tried it on a Linux machine, and indeed, there does not seem to be a problem.
A quick google search reveals that this seems to happen occasionally on Mac systems:
https://stackoverflow.com/questions/23814541/paraview-possible-mismatch-of-datasize-with-declaration-error
Best, Philipp
