Imposing two different boundary conditions on some sides of a square
7 years 10 months ago #296
by Karatza
In order to impose two different boundary conditions on some sides of a square I would like to set two different functions on two different boundaries. However, when trying to call
twice, I find that the second call overwrites values computed by the first one. Is there a way to have GridFunction.Set only change the degrees of freedom associated to the boundary passed as definedon kwarg?
Other related thoughts:
a) I am aware that on a square I could probably come up with a simple myfunc12 that is a combination of myfunc1 and myfunc2 and features the correct expression on both boundaries. However, I would not like to do so because the square is just the first step towards more complex domains where finding the correct combination would be cumbersome.
b) I had also thought of defining two different functions and summing them, but that would give a boundary value of 2 on the top-right corner, wouldn't it? Please find a simple example in the code below:
Best Wishes
M.
GridFunction.Set
from time import sleep
ngsglobals.msg_level = 0
geo.AddRectangle((0., 0.), (1, 1), leftdomain=1, rightdomain=0, bcs=["Bottom", "Right", "Top", "Left"])
V = H1(mesh, order=1)
u = GridFunction(V)
myfunc1 = y
u.Set(myfunc1, definedon=mesh.Boundaries("Right"))
Draw(u)
sleep(1)
myfunc2 = x
u.Set(myfunc2, definedon=mesh.Boundaries("Top"))
Draw(u)
Best Wishes
M.
7 years 10 months ago #300
Replied by christopher on topic Imposing two different boundary conditions on some sides of a square
The way to go here is to define a coefficient function depending on the boundary condition and then setting the Gridfunction to this function:
cf = CoefficientFunction([y if bc=="Right" else x if bc=="Top" else 0 for bc in mesh.GetBoundaries()])
u.Set(cf, definedon=mesh.Boundaries("Right|Top"))
The following user(s) said Thank You: Karatza
7 years 10 months ago #301
by Karatza
Replied by Karatza on topic Imposing two different boundary conditions on some sides of a square
Is there a way maybe to set that coefficient function without resetting to zero the degrees of freedom in the interior of the domain? Thanks M.
7 years 10 months ago #304
You can store the function in a temporary vector and then add them together:
If they have both values on the same boundaries then you only want to set these values:
tmp = u.vec.CreateVector()
tmp.data = u.vec
u.Set(x,definedon=mesh.Boundaries("Bottom"))
u.vec.data += tmp
setdofs = BitArray(V.ndof)
setdofs.Clear()
for el in V.Elements(BND):
if el.mat in ("Top","Right"):
for dof in el.dofs:
setdofs.Set(dof)
tmp.data = u.vec
for dnr in range(V.ndof):
if setdofs[dnr]:
u.vec[dnr] = tmp[dnr]
