petsc linking
6 years 10 months ago #1343 by tomathew
petsc linking was created by tomathew
hello, I would like to know if its possible to use PETSc solvers in NGsolve.
Regards
Tom
6 years 10 months ago - 6 years 10 months ago #1349 by christopher
Replied by christopher on topic petsc linking
Hi Tom,
actually I was interested in this for some time now, your question pushed me to try it ;)
It should be possible using the petsc4py interface. Note that I have no experience at all with petsc and the documentation of their Python interface is not existent... Maybe some things can be done more elegant ;)
I've modified the poisson.py example to use a petsc solver, interfacing with numpy/scipy. Note that on our side no copies are made only type conversions - petsc may do copy / mpi communcations
First we set up the ngsolve problem:
import petsc4py petsc4py.init() import petsc4py.PETSc as psc import numpy as np from ngsolve import * from scipy.sparse import csr_matrix from netgen.geom2d import unit_square mesh = Mesh(unit_square.GenerateMesh(maxh=0.2)) fes = H1(mesh, order=3) u,v = fes.TnT() f = LinearForm(fes) f += SymbolicLFI(32 * (y*(1-y)+x*(1-x)) * v) a = BilinearForm(fes) a += SymbolicBFI(grad(u)*grad(v)) a += SymbolicBFI(1e6* u*v, definedon=mesh.Boundaries("top|bottom|right|left")) a.Assemble() f.Assemble() gfu = GridFunction(fes)
Then wrap our data with petsc classes and solve there (and draw the solution):
fpsc = psc.Vec() fpsc.createWithArray(f.vec.FV().NumPy()) spy_csr = csr_matrix(a.mat.CSR(), shape=(a.mat.height, a.mat.width)) apsc = psc.Mat().createAIJ(size=spy_csr.shape) apsc.setUp() (Istart, Iend) = apsc.getOwnershipRange() ai = spy_csr.indptr[Istart:Iend+1] - spy_csr.indptr[Istart] aj = spy_csr.indices[spy_csr.indptr[Istart]:spy_csr.indptr[Iend]] av = spy_csr.data[spy_csr.indptr[Istart]:spy_csr.indptr[Iend]] apsc.setValuesCSR(ai,aj,av) apsc.assemble() ksp = psc.KSP() ksp.create() ksp.setOperators(apsc) upsc = psc.Vec() upsc.createWithArray(gfu.vec.FV().NumPy()) ksp.solve(fpsc,upsc) Draw (gfu)
Since petsc writes the solution into our vector I assume at least for the vectors there are no copies involved.
I don't know how to set dirichlet (non free dofs) for petsc so that it only solves on sub matrices, thats why I implemented the dirichlet boundaries with penalty terms.
Last edit: 6 years 10 months ago by christopher.
6 years 10 months ago #1351 by tomathew
Replied by tomathew on topic petsc linking
Thank you very much. I'm would like to try my problem in NGSolve as it supports p-refinement. I work on Maxwell's equations and will get back to you after trying my problem using this script. Thanks again and merry x'mas !
regards
