Moment Force
6 years 11 months ago - 6 years 10 months ago #1297 by Username
Moment Force was created by Username
I have a problem with moment application. Due the fact that force moment is a force couple, it is logical to assume that it is enough to apply two forces to set rotation of the geometry.
Suppose there is an area of geometry (A), Figure 1 . The rotational center (O) and the point of application of the force F1 (OF1) I can specify by the node number. The force vector F1 as a function of two coefficients (CoefficientFunction ((x, y))).
The question is how to deal with the OF2 point, which is outside the area (A)? Should I create a node in the computational mesh at the point OF2 and explicitly apply the force F2 to it?
Thank you in advance!
Yours sincerely, Aleksandr.
Last edit: 6 years 10 months ago by Username.
