Partial Static Condensation
6 years 11 months ago #1285 by Sivas
I am trying to test the preconditioner in the paper ( arxiv.org/abs/1801.04707 , doi.org/10.1007/s10915-018-0760-4 ). There, only the momentum block is condensed. I am trying to replicate the same by changing CouplingType of the local_dof corresponding to pressure unknowns. However, when I solve the resulting system, I get a solution which does not make sense. Is this the intended way? Or should I be doing it in a more manual way using multiple bilinear forms?
Abdullah Ali Sivas
6 years 11 months ago #1287 by joachim
Replied by joachim on topic Partial Static Condensation
Hi Abdullah,
having hybrid variables for the pressure you should be able to condense also the element-wise pressure. Yes, you do so by setting the coupling-type.
for debugging, you can dump and check element-matrices as follows :
SetTestoutFile ("test.out")
bf = BilinearForm(..., printelmat=True)
best,
The following user(s) said Thank You: Sivas
6 years 11 months ago #1290 by Sivas
Replied by Sivas on topic Partial Static Condensation
Hi Joachim,
Thanks for your reply. I now know that I am on the correct route! Also printelmat will definitely be useful for debugging purposes.
However, what I mean is if I try to solve the system described in Eqs. (54)-(55), i.e. eliminating both element momentum and elemnent pressure, -for test purposes using a direct solver- I get the correct solution. However, if I try to solve the system as described in Eqs. (65)-(66) (by setting the coupling type of element pressure unknowns to interface dofs for example), I get a solution which does not make sense.
Should I share my code? Would it better that way?
Best wishes,
Abdullah Ali Sivas
6 years 11 months ago #1291 by christopher
Hi Abdullah,
if you attach a small test example we can have a look at it.
6 years 11 months ago #1292 by Sivas
Hi Christopher,
Attached I am sending an implementation of the method. I am using the variable eliminate_up to switch between condensing both u and p and condensing only u. I am setting the coupling type in lines 74-76. I appreciate your time.
Thanks a lot,
Abdullah Ali Sivas
6 years 11 months ago #1293 by joachim
Hi Abdullah,
after changing the coupling-types, you have to update internal tables by calling X.FinalizeUpdate()
Then both versions produce the same result,
best, Joachim
