Stokes Equtions with pure Dirichlet boundary
7 years 4 weeks ago - 7 years 4 weeks ago #1225
by noname
Stokes Equtions with pure Dirichlet boundary was created by noname
Hello everyone,
I am trying to solve Stokes equations on a unit square with pure Dirichlet boundary conditions. I know in this case I need to modify the bilinear form, otherwise the solution is unstable. I have taken a look to the tutorials but they all consider homogenous Neumann conditions in on of the boundaries, none of them is pure Dirichlet. I am trying something like this (adding a lagrange multiplier to the bilinear form to incorporate pure Dirichlet bcs)
But the results makes no sense.. Anyone knows how to impose this kind of boundary condition?
Thanks in advance.
geo.AddRectangle( (-1, -1), (1, 1), bcs = ("wall" , "outlet", "wall", "inlet"))
mesh.Curve(3)
Draw (mesh)
V = VectorH1(mesh, order=2, dirichlet="wall|inlet|outlet")
Q = H1(mesh, order=1)
X = FESpace([V,Q])
u,p = X.TrialFunction()
v,q = X.TestFunction()
r = Q.TrialFunction()
s = Q.TestFunction()
a = BilinearForm(X)
a += SymbolicBFI(InnerProduct(grad(u),grad(v))+div(u)*q+div(v)*p)
a += SymbolicBFI(p*s+q*r)
gfu = GridFunction(X)
res = gfu.vec.CreateVector()
res.data = -a.mat * gfu.vec
inv = a.mat.Inverse(freedofs=X.FreeDofs())
gfu.vec.data += inv * res
Thanks in advance.
Last edit: 7 years 4 weeks ago by noname.
7 years 2 weeks ago - 7 years 2 weeks ago #1244
by plederer
Replied by plederer on topic Stokes Equtions with pure Dirichlet boundary
You implemented Dirchlet BC on the whole domain correctly. I am not sure what's your intention behind adding the term
However, of course you need to add a driving force, otherwise your solution is zero. Your code without your mysterious term and an example force:
#mesh.Curve(3)
Draw (mesh)
X = FESpace([V,Q])
a = BilinearForm(X)
#a += SymbolicBFI(p*s+q*r)
f = LinearForm(X)
f += SymbolicLFI(-x*v[1])
res.data = f.vec -a.mat * gfu.vec
Draw(gfu.components[0], mesh, "vel")
Last edit: 7 years 2 weeks ago by plederer.
