Accessing Element Information
7 years 5 days ago #1221 by THaubold
i'm planning to implement the HP-Finite Element Method by Melenk and Wohlmuth (2001) using the Python Framework. Since i'm able to set the polynomial degree with ngsolve, this shouldn't be a problem.
Though for the error estimator or predicted refinement rate i need to access two information and i'm not sure how to do this.
  1. Is there something like a getOrder() function to access the polynomial order of an element?
  2. Let's say i h-refine one element, how can i determine the element number of the sons of this element?
Tim
7 years 5 days ago #1223 by joachim
Hi Tim,
not all hp-functionality of NGSolve is wrapped to Python, yet. It will improve over the next weeks.
I just added the GetOrder function. You can query the order for each cell, face, and edge. Only isotropic order is supported (the C++ code supports anisotropic order as well). It will be in the upcoming nightly release.
To the second question: You cannot ask for the childs, but you can ask for the parent element: mesh.GetParentElement.
The following user(s) said Thank You: THaubold
