using orderinner with H1 space
- rhebergens
- Junior Member
7 years 1 month ago #1189
by rhebergens
using orderinner with H1 space was created by rhebergens
I saw in this example that it is possible to set orderinner=0 on HDiv spaces:
ngsolve.org/docu/nightly/i-tutorials/uni...der/fourthorder.html
I tried setting orderinner=0 on an H1 space, but I get the error message:
WARNING: kwarg 'orderinner' is an undocumented flags option for class <class 'ngsolve.comp.H1'>, maybe there is a typo?
I was wondering if there may be a different way to remove the inner basisfunctions of H1?
Thanks,
Sander
Thanks,
Sander
7 years 1 month ago #1190
Replied by joachim on topic using orderinner with H1 space
Hi Sander,
Although it is undocumented, "orderinner" for H1 should work as well.
As in 2.6 Stokes equation, you can set the order for node-types:
V = H1(mesh, order=2, dirichlet="wall|inlet|cyl")
V.SetOrder(TRIG,3)
With V.SetOrder(TRIG,1) you disable the interior bubbles for triangular elements in 2D , and triangular faces in 3D.
To see what you get you can explore the dofs of elements and nodes, see the tutorial here:
ngsolve.org/docu/latest/i-tutorials/unit...ntId-and-Ngs_Element
V.SetOrder(TRIG,3)
- rhebergens
- Junior Member
7 years 1 month ago #1191
by rhebergens
Replied by rhebergens on topic using orderinner with H1 space
Hi Joachim,
Thanks for the response. So both
and
should give the same result and I can just ignore the warning
A follow up question, if I explore the dofs using
I find whether I use
or
, the same dofs are printed to screen. Is it correct to assume that although the dofs for
are printed to screen, they are not actually used?
Thanks,
Sander
V = H1(mesh, order=order, dirichlet="bottom|right|top|left")
V.SetOrder(TRIG,1)
and
V = H1(mesh, order=order, orderinner=0, dirichlet="bottom|right|top|left")
for el in V.Elements(VOL):
print(type(el))
print (el.dofs)
V.SetOrder(TRIG,1)
V.SetOrder(TRIG,2)
V.SetOrder(TRIG,1)
Thanks,
Sander
7 years 1 month ago #1192
you get a difference if you set
or higher.
H1 - trig-bubbles start with order 3
The order on the edges can be set by:
- Joachim
V.SetOrder(TRIG,3)
V.SetOrder(SEGM,2)
- Joachim
The following user(s) said Thank You: rhebergens
Time to create page: 0.177 seconds
