ArnoldiSolver
7 years 11 months ago - 7 years 11 months ago #227
by there
ArnoldiSolver was created by there
Hi:
I am using ArnoldiSolver to compute an eigenvalue problem, it gave eigenvalues around 1e+290. The following error showed up:
"Solve Hessenberg evp with Lapack ... error in eigensolver, info = 21".
I've tested several other eigenvalue problems using ArnoldiSolver and they worked well in those case.
I believe the input matrices are not the causes, since "scipy.sparse.linalg.eigs" gave correct eigenvalues (it is just very very slow...).
Shawn
Shawn
Last edit: 7 years 11 months ago by there.
7 years 11 months ago #228
by there
Replied by there on topic ArnoldiSolver
It's probably because I'm using mixed elements, where "CouplingType" has to be treated carefully?
7 years 11 months ago - 7 years 11 months ago #237
Replied by christopher on topic ArnoldiSolver
Hi Shawn,
Yes, this may be the case. Lapack is somehow trying to invert a singular matrix. Could you provide a small test case? I've just tried solving a mixed eigenvalue problem and it worked...
Last edit: 7 years 11 months ago by christopher.
7 years 11 months ago #250
by there
Thank you very much Christopher. I think the ArnoldiSolver is working well. I realized the problem is possibly that I didn't update ngsolve to the latest version...
I currently have trouble updating ngsolve since I accidentally deleted mac-based-python2.7!
