BFGS update error2 ???
8 years 1 month ago #151
by DrTSPC
BFGS update error2 ??? was created by DrTSPC
I am concerned about the mesh that results in a case where the ref. error is displayed.
In the attached file, in the screen oiutput section:
Note that after several announcements of "start tetmeshing", success is declared.
A couple of lines below, the ref. error is displayed.
Upon manually loading the resultant mesh (gui), I notice differences in node and element counts.
Key question: Is the mesh a good mesh? When I ask netgen (gui) to check the mesh, I did not detect a response.
Thanks,
Tim
Thanks,
Tim
8 years 1 month ago #154
Replied by joachim on topic BFGS update error2 ???
if you load the .vol-file into netgen-gui, you can select "Mesh" -> "Mesh Quality" and you will obtain minimal/maximal angles, which shall be bounded away from 0 and 180,
