Volume meshing surface meshes with intended holes.
8 years 2 months ago - 8 years 2 months ago #122 by DrTSPC
I have a surface mesh which has a hole. I looked around, but found no info on flags or special commands needed to process such meshes. To generate the volume mesh, I run the script:
import netgen.meshing as meshing
mesh = meshing.Mesh()
mesh.Load("srfmsh_in_2.vol")
mesh.GenerateVolumeMesh(meshing.MeshingParameters())
mesh.Save("out_in.vol")
The mesh (srfmsh_in_2.vol) seems clean - netgen doesn't complain, and it is not a huge mesh (~63K faces). After ~1/2 hour, several notifications "start tetmeshing", and many 'Smooth Mesh' steps noted in the gui pane . . . netgen dies. I include the output below.
Any pointers?
Regards,
Tim
NETGEN-6.2-dev
togl-version : 2
OCC module loaded
loading ngsolve library
NGSolve-6.2.1707-81-g909f6c6e
Using Lapack
Including sparse direct solver Pardiso
Running parallel using 4 thread(s)
importing NGSolve-6.2.1707-81-g909f6c6e
(should) load python file 'script_2.py'
generate vol mesh
Meshing subdomain 1 of 1
Delaunay meshing
start tetmeshing
start tetmeshing
start tetmeshing
start tetmeshing
start tetmeshing
start tetmeshing
start tetmeshing
start tetmeshing
start tetmeshing
start tetmeshing
File "<string>", line 5, in <module>
RuntimeError: Caught an unknown exception!
Finished executing script_2.py
Last edit: 8 years 2 months ago by DrTSPC. Reason: added a word
8 years 2 months ago #123 by christopher
Could you post the surface mesh somewhere so we can have a look? What do you mean by holes in the surface mesh? How shall they be volume meshed?
8 years 2 months ago - 8 years 2 months ago #124 by DrTSPC
Christopher:
The file is attached.
Tim
Last edit: 8 years 2 months ago by DrTSPC. Reason: Removed file. It was passe'.
8 years 2 months ago #126 by DrTSPC
Christopher:
The (apparent) answer to my question is that no flags or settings are needed by netgen to mesh a surface mesh with a hole, as with the file I sent you.
Although netgen didn't tell me of mesh problems, nor did I see any problems using meshlab (but I don't now much about either code); I used some code that cleans surface meshes. After doing that, I did get a volume mesh out of netgen.
I don't know everything that 'cleaning' code does to the mesh, which is a concern - but that is my problem.
Thanks again,
Tim
