ngsolve.comp.MeshNode
7 years 1 month ago #721
by asilalahi
ngsolve.comp.MeshNode was created by asilalahi
I tried to retrieve the vertices coordinate using netgen 6.2, following example from:https://ngsolve.org/docu/latest/i-tutorials/unit-1.8-meshtopology/meshtopology.html
but i get this message : AttributeError: 'ngsolve.comp.MeshNode' object has no attribute 'point'
Is this feature not available in netgen 6.2?
7 years 1 month ago #722
by asilalahi
Replied by asilalahi on topic ngsolve.comp.MeshNode
never mind, i have it resolved
thanks
thanks
7 years 1 month ago #723
by asilalahi
Replied by asilalahi on topic nodal fes dof question
I was able to get the coordinate of the vertices, but how do i get the nodal coordinates used in finite element spaces (fes). i could show the nodal in each element , such as :
fes = H1(mesh, order=3)
for el in fes.Elements(VOL):
print(el.dofs[5])
how to get the coordinates of el.dofs[5] ?
Thanks
print(el.dofs[5])
Thanks
7 years 1 month ago #724
Replied by joachim on topic nodal fes dof question
our dofs are associated with mesh nodes (vertices, edges, faces, cells), but not with geometric coordinates. Only vertex nodes have coordinates.
Typically we are using hierarchical (modal) basis functions.
7 years 1 month ago - 7 years 1 month ago #725
by asilalahi
Thansk for your reply. So, could you please help to further elaborate this hierarchical basis function assignment flow?
How to find what the el.ndofs (where i >=4) 's related vertices are. ( i know the first 4 are just the vertices of the tetrahedral cell (in 3D case) and the other 6 ndofs (e.g, case of order=2) are computed from the first 4). and also, are these (4+6) ndofs mapped in serially in GridFunction(fes) ?
Futhermore, suppose i have a solution (dimension Nsol), and i want to load/map it into fes, how do i do it correctly?
Alex
Alex
Last edit: 7 years 1 month ago by asilalahi.
7 years 1 month ago #731
for the general concept of hierarchical high order finite elements have a look into literature such as Leszek Demkowicz "Computing with hp-Adaptive Finite Elemens", or the thesis of Sabine Zaglmayr:
www.numa.uni-linz.ac.at/Teaching/PhD/Finished/zaglmayr
to see a prototype implementation of high-order elements have a look into the C++ tutorials my-little-ngsolve:
github.com/NGSolve/mylittlengsolve/tree/...er/1_Basic/2_myHOFEM
The actual basis used in NGSolve does not belong to the documented user interface. It should not be relevant to the NGSolve-users. The basis may also change between versions.
