Solution in NGSolve
7 years 2 months ago #694 by Username
Solution in NGSolve was created by Username
I solve the following problem:
The cantilever beam is fixed with one end firmly fixed at the other end and loaded with a concentrated force F = 1e5 N. The beam section is a square, and a = b = 1. The beam length is l = 10. The elastic modulus is E = 2.1e11, the Poisson's ratio is nu = 0.2.
The solution in Ansys is very different from the solution of the solution in NGSolve .
Think it is because I incorrectly set load in NGSolve. Can you explain how to set the load on a certain face? What could be the reason for this difference in the result?
Files: geometry , mesh , PDE and python file .
7 years 2 months ago #696 by christopher
Replied by christopher on topic Solution in NGSolve
You have to give the surface a seperate boundary number
solid p2 = plane (10,1,1;1,0,0) -bc=3;
and then set the coefficientfunction only for bc 3 and 0 elsewhere:
# A surface force in z-direction for each piece of the boundary define coefficient coef_surface_force_z 0, 0, 1e5,
The BVP from Python doesn't work for vector valued vector entries and matrix valued matrix entries yet, so I replaced the following line in your Python file to get it running:
# BVP(bf=a, gf=u, lf=f, pre=c, maxsteps=1000).Do() u.vec.data = a.mat.Inverse(fes.FreeDofs()) * f.vec
The following user(s) said Thank You: Username
7 years 2 months ago #697 by cwinters
Replied by cwinters on topic Solution in NGSolve
you could also write everything in python.
Using linear strain and stress tensors, you get the bilinear form
a = BilinearForm(fes) a += SymbolicBFI( 2*mu*InnerProduct(epsilon(u),epsilon(v)) + lam*Trace(u.Deriv())*Trace(v.Deriv()))
and for the force you can use
force = CoefficientFunction( (0,1e5,0) ) f = LinearForm(fes) f += SymbolicLFI( force*v, definedon=mesh.Boundaries("force")) f.Assemble()
The "definedon" restricts to the surface you wanted.
